Thread: seam sealer
    Certified Gearhead dc2gs's Avatar
    Oct 2011
    cartersville
    Default seam sealer
    So I have been working on my bay, trying to clean it up and shave it a bit. I'm welding shut some of the holes in the bay and I have been taking the seam sealer off and now I'm left with all these seams. What do you guys think I should do? Grind down the seams as much as I can and then weld the seams, and apply a thin layer of filler? Or should I just grind the seams and leave it at that? I'm not doing a complete shaved bay, just want a clean bay with no seam sealer. I hate how the sealer looks. Any info will be appreciated. Thanks ia
    i steer bullets! cwood1388's Avatar
    Aiken,SC
    That would probably be the best method. grind out what you can and use filler.
    -Chris Wood
    Success is 99% failure.
    ^ x2
    Oct 2011
    cartersville
    Thanks for the help guys.
    So u wouldn't need to weld the seams at all? Has anyone done this before?
    Privateer Racing!!
    Duluth,Ga
    3m self leveling
    Oct 2011
    cartersville
    Quote Originally Posted by B18c1Turboed View Post
    3m self leveling
    Heard of that stuff. Might look in to it and see what's up with it lol
    Kennesaw, GA
    Quote Originally Posted by cwood1388 View Post
    If you want your bay to have cracks and paint peeling in a couple years, yes, use filler
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Oct 2011
    cartersville
    If I used a filler, I would use evercoat metal glaze or USC icing. I have heard real good stuff from both, they def aren't your ordinary fillers.
