Thread: lsvtec arp stud question
    barrow county
    Default lsvtec arp stud question
    i orders gsr arp studs for lsvtec conversion with gsr head.
    3 center stud on the intake side are much higher than all the other ones.
    i googled pictures and found that all studs are leveled.
    wrong studs? or is this correct?
    hard to see but it looks like the studs are too far up that i'll run out of tread before bottoming out before the nut will reach the head.
    revolution big mac's Avatar
    Once you start torquing them down the will even out make sure you put the arp grease on em
    Privateer Racing!!
    Duluth,Ga
    Nope they should all be even.
    yeah you probably have ls studs
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    Southern Speed
    Macon
    take them out and see if they are all same length. if they are all same, then you might want to clean out the holes...
    Dahlonega
    he cleaned the holes and solved the problem.
    Southern Speed
    Macon
    good deal
