Results 1 to 1 of 1
Thread: 00 Civic SI B16a2 bottom end/ -10 D16 vented valve cover
    Feb 2012
    Default 00 Civic SI B16a2 bottom end/ -10 D16 vented valve cover
    I have a B16a2 bottom end that had a cold start rod knock,but went away when oil pressure came up to normal..will be good for rebuild or parts..when pulled it had 137,xxx miles and was running when pulled..it didnt spin and bearing and was holding good oil pressure..also a D16 Vtec valve cover with -10 An fittings tig welded in place and is for catch can setups for use with turbo applicatons..asking $200 for B16(firm) $50 for valve cover..any questions txt 678-918-6010
    block #3300785
    Attached Thumbnails Attached Thumbnails -sdc11606-jpg   -sdc11608-jpg   -sdc11609-jpg   -sdc11614-jpg   -sdc11615-jpg
