Results 1 to 20 of 20
Thread: wire tuck?
    Certified Gearhead jonbuice5591's Avatar
    Oct 2011
    Clayton county
    Default wire tuck?
    about how much are wire tucks? and what all do you take out to do this? ive heard some people say that id have to get rid of different things under the hood to make it look clean. im just curious. thanks!
    Certified Gearhead Potter's Avatar
    Oct 2009
    Southside
    Re-located Battery and fuse box, remove AC compressor and lines, Power steering components, Slim radiator, and the actual tuck of the harness of course. I know there is more but thats all that I can think of as far as the basic things.
    Oct 2011
    Clayton county
    Quote Originally Posted by Potter View Post
    so battery and fuse box go in the trunk? and theres no way to keep ac and p/s? i dont have a prob with the slim radiator but no a/c, FUCK THAT! lolol
    Leave it alone!! 90% of the people who claim to wire tuck just cause bigger problems later down the road!!
    Oct 2011
    Clayton county
    Quote Originally Posted by 1civic View Post
    i just dont wanna have to get rid of the AC. ive had no ac before and i hated it..
    Oct 2009
    Southside
    Quote Originally Posted by jonbuice5591 View Post
    The trunk is probably the most common place people put the battery. Removing the AC/PS is totally up to you. You can still have a clean bay.
    Oct 2009
    Southside
    Perfection
    Now show the after pics when all the bondo cracks, and the zip-ties fall off... bahahahaha
    Then what happens??
    Newnan
    tools needed:
    multimeter
    diagonal cutting pliers
    crimpers
    wire strippers
    heat shrink butt connectors
    heat shrink of many diameters
    soldering iron
    rosin core solder
    wiring diagrams
    16 AWG wire
    zipties/fasteners
    go figure it out. not hard, just takes a little time to make it clean.
    learn to english
    Oct 2011
    Clayton county
    what types of problems could i run into later on down the road if i was to do a wire tuck?
    It's all about how it is done, every tuck I've seen is half ass'd.... It's not about just hiding everything under the dash, exposed wires is a nightmare waiting to happen.. You need soldering iron, shrink wrap, weather connectors, etc, etc, o and lots of time, 1 wire can cause 20 problems... And don't trust who say they can, go look for yourself.. Find how it's done, pick any car with wire tuck...
    my 2 cents is Just leave it be............
    Newnan
    I totally agree^^
    i've done a mild tuck before. but just headlight harnesses and fuse box relocations.
    if i were to charge, hypothetically, it'd be 300-400 or more.
    but i am not interested in taking dashes out, removing body parts and fixing wiring problems on cars.
    learn to english
    Feb 2012
    SOUTH ATLANTA
    Did a full tuck on a 94 integra... Will never atempt again. Worked fine for about 1 year then a simple check engine light led to a full harness replacement
    Oct 2011
    Clayton county
    thanks for all of the answers guys. i was just wondering what all needed to be done and what kind of problems would come out of it. ill probably never do it i just think it looks badass!!
    Senior Citizen Dylan's Avatar
    Milledgeville
    Wire tucks suck for the person who gets the car after you. I purchased a car with one and regreted it right away. Save yours and someone else's time, don't do it.
    twenty-two
    Duluth, GA
    Perfection
    A tuck with the heater core holes welded up is about the dumbest mod anyone could ever do.
    Privateer Racing!!
    Duluth,Ga
    If you have to cut or solider anything you are doing it wrong.
    ^ i'm curious, what do you mean?
    Certified Gearhead dc2gs's Avatar
    Oct 2011
    cartersville
    X2 ^^^^
    Privateer Racing!!
    Duluth,Ga
    I've done alot of wire tucks and have never needed to cut any of my harnesses.you just re run the wires in diffrent location. If you unloom harness it will help and loom back after you arrange wires
