Thread: 97 prelude with idle problems
    YoTa_BaNgEr YoTa_BoX's Avatar
    Dec 2003
    In a Yota
    Default 97 prelude with idle problems
    I just bought a 97 prelude about a week ago. The person i bought it from said the previous owner put a motor in it from an 01 prelude. Its throwing an idle sensor code of P0505 or something to that effect. Im not 100% sure if the motor is from an 01, and even if it is, does any one know if it would be the same sensor. How would I be able to check and see what year motor i have, if i need to check. block code is H22a4
    Thanks
    Life is a thought, think about it.
    GWINNETT IS GREAT!
    wowwww u got lied to
    Quote Originally Posted by YoTa_BoX View Post
    -I just bought a 97 prelude about a week ago.
    -The person i bought it from said the previous owner put a motor in it from an 01 prelude.
    -block code is F22a4
    wow
    Senior Citizen Dylan's Avatar
    Milledgeville
    EL-OH-EL!
    twenty-two
    Milledgeville
    F22a4s come from the 1990-1991 Accords...
    twenty-two
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    this thread makes no sense. He has to be misreading the engine ID. Its probably a H22A4. The car is still OBD2 if he is throwing that code. So assume this is legit for a sec:
    with a p0505, try cleaning the IACV first, reset coes and run. If you are still having problems, make sure there is power going to the IACV and test resistance through the valve. If not withing specification even after cleaning, replace it.
    P.S. The F22A4 doesnt even have a knock sensor, so unless he has a chipped OBD2 ECU (highly unlikely), he would be throwing that code as well. Give the man a break, jesus...
    98 Acura Integra LS-DD
    ??????????????????-project
    Dec 2003
    In a Yota
    Really sorry about this guys, Didnt even see i put an F there :/
    yes, its an H22 my bad. Any ways, Iv done a bit of research, and iv tried everything under the sun to fix the problem. Tried, taking off the IACV...which, the damn thing is brand new, so, it was replaced right before i got it.
    I tried, screwing the little yellow cap button thing in the Fast idle valve, that some times gets loose, i bled the coolant, to make sure there were no air pockets.
    Emergency Medical Tech
    Oct 2003
    Duluth,Ga
    Have you tried cleaning the throttle body?
    You don't know how STRONG you are until being strong is the only
    CHOICE you have!
    'Born Ready!',LJ
    Dec 2003
    In a Yota
    Yes, cleaned it when ever I messed with the Fast idle valve
