Results 1 to 5 of 5
Thread: Integra LS Idle problem
    Unknown
    Apr 2009
    Chattanooga
    Default Integra LS Idle problem
    So I have a 97 Acura Integra LS. It jumped time back in April and I just got around to putting a new belt on this week. Ran fine when I first started it, but after I turned it off and changed the oil, it threw 3 codes. Random misfire, and misfire on cylinders 1 and 2. I bought plugs and wires because I figured "why not? It has been sitting a while" but haven't put them on yet. The problem really, is that it idles and has a miss until about 3 grand, then it smooths out. Thinking it's the IACV, but not sure. Anybody wanna weigh in?
    Dec 2008
    Northside
    Could be Iacv, sounds like the miss could b dizzy since it only does it below 3k
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    LAWRENCEVILLE
    Quote Originally Posted by darthsillya1 View Post
    Since it jumped time it could be a bent valve issue, Also I have seen folks that do the timing belt and in doing dont put the cranksensor wiring back in its holders on the timing cover and the wires rub against the alterator belt and it will throw the codes your listing.
    Hella stock member!
    Unknown
    Apr 2009
    Chattanooga
    I'll check both out tomoorow and let you know. I'm gonna clean the IACV too and see what happens.
    Feb 2012
    SOUTH ATLANTA
    T-BELT tensioner could have dropped. just a suggestion. may be one of the above
