Results 1 to 16 of 16
Thread: my car is pissing me off
    Apr 2009
    warner robins
    Default my car is pissing me off
    I have a 97 ek hatch with a 95 ls motor in it. it surges constantly ive tried diff iacv a diff fast idle valve. i can re calibrate my tps and it runs fine for abt 25 mins then it starts again. it also cuts off every time i come to a stop but it always starts right back up. need some ideas.
    your mom loves me
    Senior Citizen Dylan's Avatar
    Milledgeville
    Is it throwing any diagnostic codes?
    twenty-two
    Senior Member JDMJ's Avatar
    Jun 2009
    Cedar Bluff, Alabama
    bad tps?
    Sig too big
    -IA Management
    Originally Posted by tnomud
    Aren't all IA HOndas 11-12 second cars?
    Apr 2009
    warner robins
    the only code its throwing is 17. which if i remember right is vss. not sure off the top of my head. but JDMJ that is what i am leaning towards. i just hope it is somthing simple like that. im 100% sure the wiring is right bc the car had a 3 wire iacv and im running a 2 wire with my swap.
    your mom loves me
    Apr 2009
    warner robins
    oh yea and another thing is sometimes the car runs great. and i wont have a check engine light or it wont surge. that i find strange lol.
    your mom loves me
    Check your grounds!
    Jun 2009
    When you say you recalibrate it..Is it out of whack after you set it and drive? if so..id def look into a tps.
    Sig too big
    -IA Management
    Feb 2012
    SOUTH ATLANTA
    it may be the ecu.. wiring and grounds could be fine but if its doing its own calibration and resetting to a particular pattern, it may run the way it does now
    Winder,Ga
    Its better to be pissed off then pissed on!
    It's not the speed that kill's its the sudden stop at the end.
    Some guy. CSquared's Avatar
    Quote Originally Posted by masanomi3 View Post
    Unless you like that sort of thing...
    Feb 2010
    Macon,GA
    bump my car does the same thing in my b17 eh hatch
    The universe is the limit
    Feb 2012
    SOUTH ATLANTA
    Replace your fuel pump
    Quote Originally Posted by CHRISej1X-X View Post
    fuel filter BEFORE fuel pump. always shoot for the cheapest fixes before the most expensive.
    Sep 2011
    Did you repin your Ecu? I'm positive that is your problem.
    Christina- (97 EK) - Project Boost
    Kandace (95 DC) - Project All Motor
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    Vacuum leak somewhere can cause a surging idle. Check your coolant too.
    Sent from my SAMSUNG-SGH-I997 using Tapatalk
    98 Acura Integra LS-DD
    ??????????????????-project
    Jan 2012
    How do your hoses look? You should replace all of them if you haven't already. They sometimes heat up and expand/contract and cause intermittent vacuum leaks.
