Results 1 to 17 of 17
Thread: 2004 honda accord brake issues?!
    Emergency Medical Tech
    Oct 2003
    Duluth,Ga
    Default 2004 honda accord brake issues?!
    I have some issues, and I hope some of you who are mechanically inclined can help me out.
    1. I recently changed the brake pads in my mom's car. Prior to changing the pads, the brake pedal was really soft.
    2. I bleed all the lines, and the first time I did it, I didn't pay attention to the master cylinder and let it dry out.
    3. I rebleed the whole thing again and when the car is off, the pedal get hard after a few pump.
    4. The problem is, when I turn the car on, the pedal went soft again.
    Do i need to change the master cylinder? The car has 155k miles, and I don't think my mom ever service the brakes at all. Should I try bleeding the master cylinder first before buying a new one?
    You don't know how STRONG you are until being strong is the only
    CHOICE you have!
    'Born Ready!',LJ
    LAWRENCEVILLE
    You still have air in the lines!
    Hella stock member!
    did you properly grease the slide pins? I have had a car do this when they where siezed up in the caliper, could still have air, or a bad master cylinder.
    Oct 2003
    Duluth,Ga
    I did put some anti seize on the pads. Anyway I can tell if it's a master cylinder issue?
    CHOICE you have!
    'Born Ready!',LJ
    if you pump the pedal several times does it firm up?
    Oct 2003
    Duluth,Ga
    It firm up when the vehicle is off but as soon as i turn it on, it gets soft again.
    CHOICE you have!
    'Born Ready!',LJ
    check this video...just make sure you did bleed the system completely and the air is out of the system, then chk this
    http://www.youtube.com/watch?annotat...2sk&feature=iv
    Quote Originally Posted by ruah_23 View Post
    It has a brake booster, this is normal. When its running, if you pump the pedal several times does it firm up?
    Oct 2003
    Duluth,Ga
    Nope it doesnt...it just stay soft!-
    CHOICE you have!
    'Born Ready!',LJ
    the video, do it
    If it never pumps up then im gonna say you've still got air. even a bad MC or slide pin will firm up for a moment if you pump the pedal rapidly.
    Oct 2003
    Duluth,Ga
    Sammich i havent had time to do it yet since i have to do it in the open road.
    Ill try rebleeding it again this week with the right sequence and see. Wouldnt it be soft as well when the car is off if there's still air in it?
    CHOICE you have!
    'Born Ready!',LJ
    it would be soft but not near as soft as with the car running. if its absolutely hard as a rock with the key off and the pedal is high, then theres nothing wrong with it.
    Oct 2003
    Duluth,Ga
    The pedal does go back up when the car is on. It's just goes all the way to the floor before the brake that effects..
    Ill try to rebleed it again since I bleed it out of sequence. I don't think it will fix the problem though..than Ill try the video thing...
    CHOICE you have!
    'Born Ready!',LJ
    well i replaced my master cylinder and my homeboy did that video i posted...real shit...best brakes i've felt in a car that is not newer...feels better than the one in my maxima pedal wise
    Oct 2003
    Duluth,Ga
    Ok i changed my MC today, rebleed the lines make sure all the pads are installed correctly per james advised. Turn the car on, still soft. Im gonna do the ' sammich' video thing tonight and see how it goes.
    CHOICE you have!
    'Born Ready!',LJ
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    DO NOT use anti sieze to lubricate brake parts. Problem is, when the anti sieze gets hot, it tends to stiffen up and can still cause sticking problems. I use only synthetic brake lube.
    98 Acura Integra LS-DD
    ??????????????????-project
