Results 1 to 5 of 5
Thread: clutch problem
    c-ya sirhatch1030's Avatar
    southside
    Default clutch problem
    i just put in a gsr hydro tranny in my 93 hatch, problem is it grinds in 5th gear . well if i pump the pettle a few times it shifts great in to 5th , if i dont pump it , it grinds but goes through ever other gear fine . i replaced the mastercyclinder today and no fix. any body got a ideal whats wrong
    Duluth, GA
    5th gear is steadily going bad. 3rd will be next. Then 2nd.... Then 4th.... Pretty soon you'll be driving 5 miles in first gear cuz your tranny is stuck pulling a train behind you all the way home... Well, this is what happened to my old Camry.... But your situation might be different. Are you certain the tranny was a good one before you put it in?
    Certified Gearhead YoItsCarlie's Avatar
    Mar 2011
    i would say slave is leaking down or bypassing, 5th is a hard transition to match the gears and let it "fall" into place.
    The Fuck allmotor-teg's Avatar
    Dec 2010
    down in georgia
    i would suggest you to buy some penzoil syncromesh and use it, i say that because i had mobil 1 synthetic gear oil in my transmission and out of no were my 3rd started to make a grinding noise and i went ahead and drained the transmission fluid and put some syncromesh and its a big difference, maybe it wont fix your problem but it wont hurt to try.
    Hold On Not Done Accelerating
    Dec 2008
    Northside
    Bleed it
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
