Results 1 to 13 of 13
Thread: Input Shaft Bearing
    Certified Gearhead Potter's Avatar
    Oct 2009
    Southside
    Default Input Shaft Bearing
    My transmission seems to make a very annoying noise when the clutch is not pressed in. When pressing the pedal to the floor the noise goes away. It's the ISB right? If so then is there anyone that is capable of replacing it for me? Please give me a call/text or pm with details on your price and the amount of hours that it will take to be done. I am located in Clayton County. Thanks in advance. 6785176927
    Oct 2009
    Southside
    BUMP
    The Fuck allmotor-teg's Avatar
    Dec 2010
    down in georgia
    might want to contact h22jones for that one.
    Hold On Not Done Accelerating
    Kennesaw, GA
    Throw out bearing
    Or an input shaft bearing
    Or your trans could be low on oil, or not have any in it at all
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Oct 2009
    Southside
    Quote Originally Posted by .blank cd View Post
    Throw out bearing
    From what I understand, when the throw out bearing is bad, you hear the noise when the clutch is depressed. In my case, I stop hearing the noise as soon as i press the clutch down.
    input shaft bearing will make noise on decel, accel etc. tob will make noise when clutch is engaged, but when disengaged it goes away
    Oct 2009
    Southside
    yes, that is exactly what happens.
    we can replace it for you no problem, if you have never replaced the clutch and rear main I would suggest doing it at the same time
    Oct 2009
    Southside
    The clutch has been replaced by the previous owner. The flywheel was resurfaced as well. What would be the price for the replacement?
    well the bearing is probably only 40-60$ , you just have to pull trans.
    Oct 2009
    Southside
    Bump, what about someone who can come to me and do the job?
    Southside Ridin HATCH
    Pm'd
    Oct 2009
    Southside
    Pm'd
    replied
