Results 1 to 22 of 22
Thread: vtec problem
    Certified Gearhead oreign's Avatar
    May 2011
    Default vtec problem
    every so often my vtec likes to not engage for a short period of time, or rather my vtec only likes to work for a shorter period of time.
    it stopped engaging just recently again. all that happens is when i hit 5500 you hear a louddddd roar but it doesn't pull whatsoever. what could be the issue?
    I'm running an h22a with a p13 ecu.
    Super Certified metalmatt47's Avatar
    Jun 2010
    Powder Springs, Georgia, United States
    hmm.....
    Not gonna lie, I'm not a Honda guy at all, but isn't the VTEC solenoid oil pressure controlled? Pretty sure it is...
    If so, maybe you're experiencing oil pressure issues? Oil too thick or poor quality? Maybe just a bad VTEC solenoid?
    Better let someone else chime in...
    Conformity is the jailer of freedom and the enemy of growth.
    - John F. Kennedy
    May 2011
    i've tried different solenoids and none have worked. my oil is fresh too.
    i did however clean the gasket/screen and it worked for about a month but it quit now lol.
    Senior Citizen Dylan's Avatar
    Milledgeville
    Check all of your wiring and connections. Does the check engine light come on?
    twenty-two
    Jun 2010
    Quote Originally Posted by oreign View Post
    Hmm. Seems like the common denominator is oil related. Or maybe sheer coincidence?
    Prior to cleaning, your VTEC worked intermittently correct? And after cleaning the screen it worked consistently again?
    Maybe you should look into doing that again...
    - John F. Kennedy
    May 2011
    CEL is on for EGR and who knows what else.
    Kennesaw, GA
    Hmmm
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    May 2011
    Quote Originally Posted by metalmatt47 View Post
    Cleaned screen -> Worked for 2 weeks straight without fail -> completely stopped working out of nowhere
    oh and i assumed it was the screen since it randomly stopped working so i checked to see if the screen was clogging up or something but it looks clean.
    Check for dent in the pan, even the smallest dent by pickup tube can cause this
    May 2011
    There's plenty of dents in the pan but would that really make it work on and off? If the dents really would affect it, it would seem like it would work every other time or something like that. During the time that it's working it never fails once.
    does that make sense? lol
    Certified Gearhead jtdb8's Avatar
    Oct 2011
    where everybody knows everybody
    thats a new on on me. but it could. i have seen stranger things in the automotive world.
    1-UP!
    May 2011
    halp aaa. any other fix? i'd like to try other suggestions before i go changing my pan lol
    UNITED STATES MARINE jdm7thgen's Avatar
    canton / ball ground
    Check knock sensor wire. Oil pressure sensor. Or your car is in limp mode because of the CEL.
    USMC, license to kill people for fun.
    ONCE A MARINE, ALWAYS A MARINE
    Own a gun?
    2008 HMMWV ( IED )
    1995 Infiniti G20 (current)
    2002 civic ex (sold)
    2000 Tacoma (sold)
    1985 chevy ck3500 CUCCV (sold)
    2001 Integra ls (sold)
    1989 4runner (sold, best truck I've ever owned)
    1997 cobra ( wifes car )
    Quote Originally Posted by jdm7thgen View Post
    first , you need to jump the connector and read ALL THE CODES. then maybe someone can help you a bit more. Is this in a Prelude or something else?
    LAWRENCEVILLE
    Change the dented oil pan out, emino is right about this i have seen a dented oil pan cause this issue more than a few times!
    Hella stock member!
    May 2011
    Quote Originally Posted by Apex1972 View Post
    i'll figure out all the codes tomorrow. it's in an ek coupe.
    Quote Originally Posted by silversol View Post
    i'll probably try everything else before i get a new pan lol.
    Jun 2010
    Whats stopping you from pulling the pan and knocking the dents out?
    - John F. Kennedy
    fuck man, this was happening to me in my gs-r, i cleaned the screen then it worked and did the same thing....i forgot what i did to fix it tho! fuck
    May 2011
    Quote Originally Posted by Benefit View Post
    Fffffff remember please lol
    May 2011
    problem fixed. there were loose wires on my harness so i'm assuming my passengers would kick the ecu and knock the wires around lol.
    i did go to a local shop and they told me to do what Emmino said. knock the dents out of the pan and replace the baffle if it had been bent inward.
    Ah yea, i just found the thread i posted on here about it...first i thought it was the TPS..it turned out that my speed sensor wires were causing it...
    is your ECU just chilling on the floorboard or behind the kickboard?
    May 2011
    that's probably it because one of the wires that likes to slip out is the TPS one.
    it's kinda just chilling on the floor lol
