Results 1 to 13 of 13
Thread: 95 integra gsr slight issue
    Rome,Ga
    Default 95 integra gsr slight issue
    95 integra gsr
    Only mods
    Are I/H/E
    Okay when I'm at a red light at idle
    Which is 900rpm
    Everyonce in a while when I go to leave the light the car
    Will drop to like 600-700 Rpm then rev normal.
    It does it not do it everytime!
    No CEl lights!!
    Other than that issue it runs great and idles smooth
    Certified Gearhead jtdb8's Avatar
    Oct 2011
    where everybody knows everybody
    you need to be more specific.
    what the heck is that? did you mean, it doesent do it everytime?
    you shoud be giving it gas to take off an if you are and its still droping off you need to look at your iacv, fast idle, or tps. i would say the tps is acting screwy but you would have to hook it up to a scanner an look at the data.
    1-UP!
    Senior Citizen Dylan's Avatar
    Milledgeville
    I would start off by making sure all vacuum lines are intact/undamaged.
    twenty-two
    Oct 2011
    those would cause it to ack up all the time an a fast idle/ but wouldnt hurt to check i guess.
    1-UP!
    SOUTHSIDE
    launch that bitch at 4500.....problem solved
    Oct 2011
    Quote Originally Posted by wrekonize View Post
    agreed!!!!!!!
    1-UP!
    Rome,Ga
    The prob doesn't occur everytime!
    If I barely tap the gas at idle the rpm gauge drops a little then revs
    Oct 2011
    Like a delay. You need the tps checked.
    1-UP!
    did you adjust your throttle cable?
    The Fuck allmotor-teg's Avatar
    Dec 2010
    down in georgia
    yea thats a great idea.
    ​Hold On Not Done Accelerating
    Rome,Ga
    Spark plug wire was messed up
    Thanks ia
    Milledgeville
    Quote Originally Posted by terrytowe22 View Post
    Thanks ia
    Well that was simple enough lol
    twenty-two
    Oct 2011
    good deal. always the simple things that gets over looked. lololol
    1-UP!
