Results 1 to 31 of 31
Thread: clutch
    winder
    Default clutch
    what does it mean when your clutch lets out at the top?
    The Fuck allmotor-teg's Avatar
    Dec 2010
    down in georgia
    is the way that its made instead of being like oem clutch an aftermarket will let out at the top so you wont need to let it go like a stock one, so usually aftermarket ones that are not oem will let out at the top, those usually are the stage 1,2,3,4 clutch(sorry about the explanation but thats the best i can do right now but hope it helps)
    Hold On Not Done Accelerating
    winder
    thats man
    Dec 2010
    down in georgia
    Quote Originally Posted by ludeguy420 View Post
    thats man
    if you meant thanks then no problem.
    winder
    yeah my fault thats what i ment
    Dec 2010
    down in georgia
    and about the clutch they take some time to learn them if you are used to oem stock ones. i know because i have a stage 3 6 puck clutch with an exedy 8 lbs flywheel and its a huge difference.
    winder
    im not sure what kinda of clutch it has to tell you the truth.. i wish i knew
    barrow county
    stage 1 are suppose to be just like oem ( stock ) clutch.
    the ( where it catch ) depends on the pressure plate
    winder
    Quote Originally Posted by Theycall_Metue View Post
    so if it catchs at the top does that mean my pressure plate is going bad?
    Dec 2010
    down in georgia
    ^ no it doesnt mean that is going bad mine is like that and its in perfect shape i seen it after loads of hard shifts.
    winder
    im not a fan of how it catchs at the top.. i have never had a car that does that
    Oct 2009
    c
    Not sure what you mean by letting out at the top... Like a slipping clutch?
    http://youtu.be/WhGjp2EAzJk?t=27s
    If you're talking about engagement point, is a hydraulic or cable clutch?
    Dec 2010
    down in georgia
    more then likely is an aftermarket clutch and thats why because when i first got mine it felt very weird.
    Dec 2010
    down in georgia
    Quote Originally Posted by thesammy View Post
    maybe this??
    http://www.youtube.com/watch?v=0Uzs6_sfU6g
    winder
    its not slipping to me.. it has been that way since i have bought the car over a year ago
    winder
    an im not sure if its a cable or hydraulic.. im not with the car at the moment.. i will look when i get home
    Oct 2009
    c
    Does it feel like you're spinning your tires and not going anywhere?
    Dec 2010
    down in georgia
    what year is the car??
    winder
    no when it spins both front tires will spin some times most of the time the right one will spin
    Quote Originally Posted by allmotor-teg View Post
    its a 94 eg with a d16y7 from a 98 civic
    Oct 2009
    c
    Are you sure? Lol. I thought my wheels were spinning for a little bit. But I decided to gun it 6th, and theres no way my wheels are losing traction then.
    Dec 2010
    down in georgia
    def a hydro transmission.
    THAONLYDAW/SISEATS
    Winder
    I told u its needs an adjustment fool and if u have an after market clutch and Ur pedal is allmost before it grabs that's not right either it should grab if u wiggle Ur big toe
    Sent from my PG06100 using Tapatalk
    winder
    haha yeah im sure.. you can hear them an smell some rubber burning.. if yall are located near auburn or lawrenciville i can let you drive it some day.. an tell me whatcha think
    winder
    Quote Originally Posted by SX-MAN View Post
    let me know when yuo get home man an i will stop by tonight an you tell me whats up. just text me
    winder
    thanks i have never checked
    THAONLYDAW/SISEATS
    Winder
    Jeez kid
    winder
    Jeez kid
    what?
    Dec 2010
    down in georgia
    i am going by the year so its def a hydro:
    in civics:
    92 and after - hydro
    pre 92 - cable
    tegs:
    94 and after - hydro
    pre 94 - cable
    if it bothers you that much you might want to swap to stock OEM.
    Oct 2009
    c
    You can adjust the point of engagement if that helps you any. There should be some sort of bolt and rod on the clutch pedal that goes to the slave cylinder. Play with it both ways and see if it still happens.
    winder
    i have gottin used to it now.. but i kinda want to trade it for something different
    winder
    i will have to try that when i get home
