Thread: d series parts /ef years/ FREE kinda/read
    in my own little world one11racing's Avatar
    Default d series parts /ef years/ FREE kinda/read
    ok hear is the deal i have to move by dec9 . and i have hurt my hand. I need to cut up a shell i have in my backyard some of these parts are on theis shell. if some of you guys want to help cut this thing up and you can take the parts you want off it. I have a sawsal with new blades and a compressor I just need the help to cut it and get rid of it. email or call me. 678-772-5974.
    i will furnish the vin numbers upon request!
    1 d16a6 oil pan
    2 set of a6 internals, 1 in good ahpe, one that has a broken rod
    crx cooling fans
    stock a6 header and down pipe
    a6 dizzy not sure if it works
    d sereis alt
    rear stock sway setup of a crx
    b18b stock upper header
    internals from an cable si tranny
    dx airbox stock- 94 dx
    misc b series mounts of 94 ls - no tranny mounts- just engine
    crx gas tank
    crx brake booster
    some other mis crx stuff left off my wrecked shell.
    -sean
    [email protected]
    i might need that good a6 block, i'll let you know.
    cool, that one is on the engine stand.. could really use someone that was a cutting torch also...
    good block number provided to QD ( it is #4601640) will get the other number in the day light as still in the car..
    bad block number is 2316247
    that should be about it..
    to the top
    Jan 2010
    Forest park
    If I come by can I get that stock manafold
    100% PLATAN0
    where r u located? pm me
