Results 1 to 18 of 18
Thread: 1994 Ford Mustang GT vert
    function>form boosted347's Avatar
    Nov 2009
    Columbus, GA
    Default 1994 Ford Mustang GT vert
    Make: Ford
    Model: Mustang
    Year: 1994
    Mileage: 15x,xxx
    Options: Convertible
    Engine: 347
    VIN#: xxxxxxxtxrf176055
    Condition: Good
    Mods: 347 stroker and powerglide trans
    Price: $12,000 obo
    The time has come the snail is for sale. Up for sale is my 94 Mustang GT convertible, car has 159k on it, motor has less than 5k. The car is in very clean shape both interior and exterior, minor scratches and dings as you would expect from a 17 year old car. I have poured tons of money into this car and know it will make whoever owns it happy. Here is the build list, I have well over the asking price in this car, without the cost of the car lol
    Engine Mods:
    “X” Block bored .030 over machined and painted (victory red)
    Forged .030 pistons (20.1cc dish)
    SCAT forged I-beam rods
    SCAT steel stroker crank 3.400 stroke
    Edelbrock E-street aluminum heads 1.90 ex/1.60 in
    TFS .615 lift single valve springs
    SBC 1.6 roller rocker arms
    TFS lifters
    Thermostat removed, replaced with Moroso billet restrictor plate
    Ported Edelbrock performer lower intake
    FRPP green top 42 lb injectors
    Walbro 255 lph high pressure pump
    3/8” phenolic spacer
    Custom sheet metal upper intake manifold
    FRPP F-303 camshaft
    TFS Hardened Pushrods
    Trickflow TB elbow adapter
    75mm Throttle body (no egr)
    C&L 88mm MAF with 42lb calibration tube
    All ARP hardware/ grade 8
    Billet steel Main Girdle
    High pressure melling oil pump
    FRPP oil filter relocator
    347 stroker valve covers
    Taylor Stainless Braided wires
    MSD coil
    Billet Smog pump delete
    FRPP underdrive pulleys
    Cometic MLS headgaskets
    28 oz balanced harmonic balancer
    All fel-pro gaskets
    Battery relocated to the trunk
    MLS head gaskets
    Turbo Setup:
    Bullseye s364 turbo, polished race cover w/ anti surge ring .71 ar ceramic coated hotside w/ 3" v-band
    Flipped shorty headers that retain ac and ps
    Custom 2.5" crossover pipe
    3" downpipe
    3" intercooler piping
    Cxracing intercooler (27x14x3) keeps IATs at 70 degrees
    Tial 38mm MVS wastegate w/ 7 psi spring in it currently will come with 10 psi and 15 psi springs set
    All hotside components are header wrapped
    Transmission Setup:
    1.76 powerglide, stock case, turbo spline
    JW aluminum SFI bellhousing
    JW “The Wheel” 157 tooth 28 oz. balance TH350/400 bolt pattern
    JW trans brake with mounted button
    Custom built driveshaft, th350 yoke solid trunions
    B&M pro stick shifter, 2 speed gate w/ reverse lockout, mounted in stock location, with B&M shifter cable
    3000 stall race hub converter, just rebuilt new hub
    Trans is built, has been 5.50 in previous car
    Custom cross member in stock location
    New sway bar links
    BMR driveshaft safety loop
    LMR weld in subframe connectors
    17” anthracite bullits
    245/45/17 michelin pilot sprts up front
    275/45/17 Nitto NT05 extreme drag radials (less than 1000 miles)
    Rear end:
    FRPP 3.73s rear gears (professionally installed)
    FRPP 3.08s will come with the car, as will FRPP 3.27s
    As for numbers i dont know what kind of hp it puts down, havent had a chance to take it down to the dyno. I took it to ISD in spring on the current turbo setup but on a stock t5 trans and DRs, it went 12.2@126 w/ a 2.3 60' and a slipping clutch. On the glide and slicks (not included) i have no doubts this is a mid to high 10 second car. The car weighs 4,000 lbs so that can give you a rough estimate of the power she has.
    Here are a few videos of the car
    best way to reach me is pm on here
    Interior is tan cloth and has one very small tear that showed up last week in the lumbar support. Ill get pics up of the interior when i can make it back home
    1990 Mustang Coupe...turbo lq4 through the glide
    Greene/Athens
    Sick!!! Sweet car bro!!
    Nov 2009
    Columbus, GA
    Appreciate it man
    Senior Member VIP Style's Avatar
    LOL, I saw the price before the pictures and was like "12,000 for a 94 stang, WTF"? Now I see why, stang is badass. GLWS.
    Nov 2009
    Columbus, GA
    Quote Originally Posted by VIP Style View Post
    Ha appreciate it man
    Senior Member sprix!'s Avatar
    That thing sounds like a beast. Good luck with your sale.
    G37s 6MT/coupe
    Nov 2009
    Columbus, GA
    Bump! Cash talks guys... someone buy this beast and enjoy it. Took it to the track this weekend and she yanked the front wheel disregard my friends commentary lol. If you or anyone is interested it will be present at IFO on the 19th
    Duluth, GA
    They let you run that shit with no cage? I'd be scared as hell to do that. Awesome car though. Good luck.
    Nov 2009
    Columbus, GA
    Quote Originally Posted by Captain-Obvious™ View Post
    Haha im not lying when i say you could pull up with a beer in between your legs and run down the track lol, but its also been 126 in the 1/4 with no cage...at least it has a drive shaft safety loop, SFI flexplate, SFI bellhousing, and solid driveshaft but thanks for the compliments man i love this car and no one really expects it out of a vert
    Duluth, GA
    Still, you got balls for driving that down the 1/4 with no cage, even more so because it's a vert.
    Nov 2009
    Columbus, GA
    Bump...may be interested in trades...make an offer
    Senior Member SHHHH's Avatar
    Aug 2009
    New York Upstate/ Newnan,GA
    Really cool build
    No one ever expects a vert. They make really nice cruisers and a hell of a sleeper.
    2013 GT500
    1989 Mustang 5.0
    Nov 2009
    Columbus, GA
    Quote Originally Posted by SHHHH View Post
    Really cool build
    BUMP!
    Thanks man im really sad to see her go but im at a juncture where i need a good reliable DD got a v8 240 project to replace her with though lol
    Nov 2009
    Columbus, GA
    Bump...looking to possibly trade for 4 door car, possibly is300, srt4, etc
    Nov 2009
    Columbus, GA
    Bump...price drop 11k still open to possible trades
    Nov 2009
    Columbus, GA
    Bump
    Nov 2009
    Columbus, GA
    Bump...open to trades other than 4 doors now...looking for dd types cars. Dont be afraid to make an offer
    Nov 2009
    Columbus, GA
    Bump 10k takes it...money talks
