Thread: heat blows cold
    Senior Member EJdm's Avatar
    Default heat blows cold
    91 accord heat and AC blows cold. I remove the climate control and found the connection to the heat not hooked up so I fixed that and still no heat. Any help would be great thanks
    "Arriving at one goal is the starting point to another." – John Dewey
    Duluth, GA
    Try manually opening the valve that's in the coolant line that runs to the heater core under the dash. That's where the connection on the climate control should connect to.
    05srt4
    Jun 2009
    Upatoi, Georgia, United States
    x2^
    Thermostat??
    Certified Gearhead YoItsCarlie's Avatar
    Mar 2011
    bypassed heater core, thermostat, bad/disconnected on/off valve for heat.
    Got it fix thanks guys, it was the heat valve
