Thread: New Suspension - need camber adjustments
    BarnDog296 BarnDog296's Avatar
    Clairmont
    Default New Suspension - need camber adjustments
    Alright guys,
    I have done some research on installing a suspension and i am putting in AGX shocks/struts with Tein Springs. this setup is going to drop my car about 1.5" or so, I need some help with something though.
    When it drops the car, im going to have a problem with the tires starting to fade away poorly. Obviously I am going to have to get some sort of camber setup.
    I have gone onto E-bay to find some parts, but it seems that nothing is name brand in there, and I get lost b/c I cant look-up any of the parts.
    Does anyone have any suggestions on camber parts, I have found the rear adjustable, but I have no idea what adjusts the front on a 240?
    What are the good brands for these parts?
    Drifter/Kneedragger
    Buford, GA, USA
    1.5" won't give you lots of camber. any good alignment shop can easily get back near stock specs using the stock adjustment points.
    generally if you want to adjust the front on the 240 you need camber plates, but when adding camber plates to a spring/shock setup it'll negate the drop from your front springs due to the height it adds to the strut assembly.
    up the street dumping fuel in 3rd
    I dont think a 1.5" drop is gonna need any camber plates. You may need some but I doubt it.
    Quote Originally Posted by Brett
    Rule #1, The pussy must be eatin, Thats my rule atleast...lol
    Saint
    Behind you
    i have the same setup and all i needed is an alignment
    i agree with them 1.5 isnt enough to throw things off that much. if you bought sportlines or something like then yeah you'd need bolts. you are aware that droping the car that much will void the warrenty on the agx shocks right? you should buy rsr, they will make the car handle better and wont void the agx warrenty.
    Jan 2003
    Thumbs up
    i think kyb's warranty is 1.5 inch... shameless plug: i have a set of rsr race springs that i'm selling lol -
    you don't need any camber crap just get it aligned and you're good to go.
    fyi the front is a mac strut set up and "doesn't" have a way to adjust camber stock, i say "doesn't" because you can always buy the eccentric bolts but i dunno how willing normal alignment shop mechanics are willing to deal with them, though i don't see it being a problem.
    Clairmont
    how much of a drop do the RSRs have? i really do want the 1.5 inch drop. I have large tires and cant afford too much of a drop, but some would definately make the car handle and look better.
    Drifter/Kneedragger
    Buford, GA, USA
    Quote Originally Posted by BarnDog296
    what do you have on there? a set of 33" swampers? if my car will sit down over 17x9.5 wheels then i'd assume whatever you have on yours will fit fine.
    I keep it real. AFSil80's Avatar
    Savannah
    Quote Originally Posted by HiPSI
    Hahahahahahahahaha!
    +1 for the laugh!
    -91 240SX -- CA18 Power...SOLD, now terrorizing the streets of Alabama
