Thread: B16 Cable Trans ???
    Certified Gearhead DA9_Vito's Avatar
    Dec 2009
    Forsyth,GA
    Default B16 Cable Trans ???
    If i put a b16 cable trans on my car do i have to change my clutch or are the splines the same? I have a b18A1. And is it really worth it.
    Certified Gearhead dc2gs's Avatar
    Oct 2011
    cartersville
    The tranny will bolt right in. Are you planning on dd or track? Gears are shorter than the ones in the ls trans. You will benefit from the shorter gears but idk if you want it in a dd.
    Dec 2009
    Forsyth,GA
    Quote Originally Posted by dc2gs View Post
    Ive been told i can put the LS 5th gear in for gas milage. And just keep everything else b16 gears. If i did keep the b16 5th gear what kinda rpm in 5th would i be around. the LS runs around 2500rpm at 65mph
    Oct 2011
    cartersville
    If i remember correct its about 3500 or 4000 at around 65mph. I would personally just put an ls 5th gear in it.
    It depends on what trans you have now. If it is a 92-93 integra ys1 trans it has a larger spline which is the same as a 94-01 trans. Just count the splines.
    My line of work
    www.internationaljets.com
    Dec 2009
    Forsyth,GA
    Quote Originally Posted by Starrfire View Post
    yea i looked closer today and its right at 3500rpm at 65mph. and its a 90. the guy says its a b16 SIR cable trans. so i assume its the correct one lol. Thanks for yalls help guys. Reps for both.
