I have several parts I need to sell in order to help fund a new motor. With that being said, prices are set to sell!
1. B18c1 Arp head studs. Only been torqued twice. $80
2. B18c1 AEBS intake manifold with a 68mm Skunk2 TB. IM and TB are both complete with working sensors. Sold
3. Tail style wastegate. Worked fine for me. $20
4. 2 Mickey Thompson slicks. 24.5/8.0-15. I purchased these from 1civic on here and I have not ran them. I paid $100, but my loss is your gain. $70
Now for the goods. I have 2 b18c1 motors. Both have issues
5. B18c1(p72) head. Complete with vtec solenoid, and other sensors. No dizzy or vc. Cams, caps, etc are there. #1 cylinder has an intake valve that's either slightly bent or stuck open. Head has never been over heated. Sold
6. B18c1(p72) short block. Was rebuild has about 30k. I personally did the rebuild. Bottom end had new rings, acl rod and main bearings, oem oil pump, oem water pump, tensioner, etc. Block was turboed on 11psi and ran great til issues were found with the #4 cylinder. Cylinder wall has a nickel size area on the cylinder wall that could be machined out. Block is complete with all sensors. No oil pan. $200
7. B18c1(p72) head and short block with issues. Motor was over boosted to to a boost controller line splitting causing the #3 cylinder wall to kick out and chew up the combustion chamber for #3 on the head. Head is sold, block still available. $100 takes it
UPROOT Photography FTW
