Results 1 to 3 of 3
Thread: bearing clearence
    Jul 2009
    Default bearing clearence
    just measured the clearence for the main bearings on a b20 using plastigage. was wondering what the factory specs are for the main and rod bearings are.
    Certified Gearhead Go_Fast's Avatar
    Jun 2010
    I-575
    got this from my integra manual in the b18b1 engine spec section. maybe this helps.
    B18b1 engine
    main bearing-to-journal oil clearance:
    no. 1,2,4, and 5 journals: standard= 0.024-0.042mm limit= 0.050mm
    no. 3 journal: standard= 0.030-0.048mm limit= 0.060mm
    SOUTHERN SPEED
    macon ga
    Thats your answer good luck man.
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
