Thread: tuning an ls/v
    Certified Gearhead Go_Fast's Avatar
    Jun 2010
    I-575
    Default tuning an ls/v
    i have a walbro 255 on my ls/v with bolt-ons. i have a walbro pump because the car used to be turbo'd. i realize the pump is no longer a necessity which leads to my question
    can a walbro 255 be tuned to operate at oem pressure?
    will i need an adjustable fpr for oem pressure?
    i was about to replace the pump and call it a day but a brand new pump is a little less than half the price of a full tune...
    should i just get it tuned now or replace the pump first?
    so you have a Ls/v running untuned? such a no no!!
    Jun 2010
    I-575
    Quote Originally Posted by 1civic View Post
    so fuel pump first or tune first?
    Quote Originally Posted by Go_Fast View Post
    255 is fine with your setup.. adj regulator helps the tuner, but it can be tuned regardless..
    Question you're asking is the 255 fine, so yes!! Get a regulator and adjust it to OEM setting... Then go get the car tuned!!
    Edit:
    If your lost then ask for the tuner's advice..
    i dont know why you are trying to get rid of the fuel pump. Keep it, its NOT overkill. YOu can tune with it fine.
    i would NOT tune it then replace it as it needs to be retuned "checked" again
    Jun 2010
    I-575
    thanks for the help guys
