Page 1 of 3 123 LastLast
Results 1 to 40 of 83
Thread: Fs : Good b series trannys for your bad b series trannys
    SOUTHERN SPEED
    macon ga
    Default Fs : Good b series trannys for your bad b series trannys
    I am offering to trade perfect shifting b series trannys for b series trannys that have a grind plus cash . I have sold over eighty trannys on here with only one that had any issues and it was my fault . i made it right plenty of people to rep me. If your tarnny is grinding dont take a chance on buying another bad one from somebody on here and threw your old one to the side . Text me and ill sell you one for about half wat you canbuy one for and your old tranny . If you dont like your gearing well you dont have to go back with the same tranny . Try a gsr instead of a ls this time . of course gsr cost more so there will be about 100 dollars difference there still not bad . Have the confidence that your getting a good tranny since your buying one from a ia sponsor (Southern Speed ) which i own .I also install lsd,final drives ,and build hybrid trannys . I always have somebody wanting something different so there is no way to list all the pricing but ill do my best to list as much as i can . I build and manual honda tranny . I will be getting into building automatics here shortly and ill let you know when that happens. I also dropped prices since im doing so many and to help you Atl guys with the drive to macon to pick them up. If you choose to keep your own tranny i can fix it while you wait but most of the time i have a tranny waiting and you can just can just dropp yours off and pick up another one . Please try to describe what your tarnny is doing to the best of your knowledge . I will pop the casing and check it out before you leave with my tranny ( takes me five minutes ). I will also take old trannys in on trade to lower prices if you have some for parts laying around . I have even been none to fix some for free if you have some nice parts trannys you want to give me.
    Text me other pricing 478-808-9122
    Pricing
    Any b or h series tranny grinding in 1 gear 200 plus your tranny.
    Any b or h series tranny grinding in 2 gears 300 plus your tranny.
    Any b or h series tranny needing a differential ( your spider gears are gone ) 250.
    Any b or h series tranny that has been run with out oil and bearings are locked up 250.
    Any b or h series tranny that needs a center support shaft bearing only 200.
    Any b or h series tranny that needs either tranny housing only ( meaning your housing is busted ) 200 .
    Adding ls fifth gear to a gsr or b16 tranny 200 extra dollars ( 100 for the gear and 100 for installing it ) when available . I dont have a life time supply but i keep them pretty regularly .
    I can also provide services with getting them pulled and installed . 300 dollars
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    AKA Stock_dc2 torqlswonder's Avatar
    Bump for you sir
    loa13 loa706's Avatar
    Jan 2010
    ICE CITY/CHATT/DALTON
    how long is one garrenteed to work?
    BLUEBERRY
    Jan 2010
    whats ur policy...any bad tranny even if one of the castings is broken cracked or has a hole in it?
    BLUEBERRY
    bump for a great guy, honest too!!!
    Macon, GA
    I can vouch for this he did my ls for me worked great
    SOUTHERN SPEED
    macon ga
    As long as your honest about whats wrong with yours i have plenty of casings and stuff will change price to to pay for casing though. The prices i listed i examples of what i would do as for different circumstances text me for a price but yes i will take any tranny in on trade what i give for it depends.
    I warranty all my work but if your looking for a 6 month warranty on transmissions that we all beat to death go some were else im not stupid by any means . The tranny will work great when you get and continue to work great as long as its taken care of with out people cramming gears . I did have a guy call me 6 months after i sold him a tranny saying it grinded twice in third at high rpms lol. Well a brand new tranny i liable to do that but i still offered to put new syncro in for 100 dollars so i do what ever i can to help out.
    SOUTHERN SPEED
    macon ga
    I had six people call today and trannys pending . Alot of ls fifth in b16 trannys . I only have four or five ls fiths so if you want one get them while they last . My dad is retired im trying to push this now to give him something to do to make a few extra dollars to blow on the si lol.
    SOUTHERN SPEED
    macon ga
    I try to keep two b16,two gsr ,and two ls trannys built all the time . As for the ls fifth i ad them if you need them i dont have them ready but it only takes just a minute.
    I also check all the slides to make sure they work perfectly . I dont just replace syncros i check the whole tranny .
    SOUTHERN SPEED
    macon ga
    If its the one im thinking about i took two trannys built one good one and checked eveything with you sitting there waiting right ?
    He has done just like everybody else on here bought a tranny from somebody that was bad . Story of everybodys life . Now buy one from a legit builder and know ist right for a more then fair price.
    Rome,Ga
    B16 trans doesn't grind but when left off gas makes loud grinding noise!
    Certified Gearhead Go_Fast's Avatar
    Jun 2010
    I-575
    i have a gsr tranny no grinds in any gear but its rough getting into gears, it seems the synchros are pretty worn out..
    how much to trade for a gsr tranny that shifts like butter?
    revolution big mac's Avatar
    hey mike i have a b16 tranny how much for one with ls fif
    SOUTHERN SPEED
    macon ga
    Text me we have prior business you get a little better deal
    SOUTHERN SPEED
    macon ga
    Text me what you want for it terrytowe22
    SOUTHERN SPEED
    macon ga
    go fast 200 for one that shifts like butter.
    yes sir you got im coming txt
    I like your idea, put this in your paid section so they dont fuck with it though!! I guess I can supply you with the extra goods, as we all know I am a tranny parts whore.
    barrow county
    how much for one without a core?
    looking for legit b16 for my build
    and also one with ls 5th
    Macon, GA
    Quote Originally Posted by h22 jones View Post
    yep that was me... btw i still need to come pick up my ds that i left there haha
    Oct 2011
    I have an LS that has about 200k on it. Nothing wrong with the tranny, its just an LS and I would like either a fresh LS or GSR. How much for either one of those trades?
    Certified Gearhead dirty5outhaz's Avatar
    Jackson, Georgia, United States
    OK ls tranny for a b16 with ls final gear?
    SOUTHERN SPEED
    macon ga
    Quote Originally Posted by CptWitwiki View Post
    Still sitting on the counter at home lol.
    SOUTHERN SPEED
    macon ga
    Text me guys easier to reply to.
    Southern Speed
    Macon
    Jeez and if there wasnt already alot of tranny parts in the office....lol
    Also a fresh gsr trans that came out my car sitting at the shop....i even have video of the last time it ever ran in the car
    SOUTHERN SPEED
    macon ga
    Quote Originally Posted by DarKStaR View Post
    Yes sir and im not scared to sell or trade his shit off either lmao.
    SOUTHERN SPEED
    macon ga
    bump big mac picked up a b16 with ls fifth today. I have his perfect gsr that he traded in on it for sale along with two more gsr trannys. I have two more b16 trannys ready to go also .
    I really didnt think this tranny thing would blew up like it has keep them coming ill be glad to help who ever i can . I only have a limited amount of parts so get them while you can . Im trying to resource some more parts to keep you guys with good trannys in your cars. Thansk to james at mainstream i think he can supply me with parts for awhile lol.
    SOUTHERN SPEED
    macon ga
    I built five trannys this weekend and still have three more to build any else need one?
    SOUTHERN SPEED
    macon ga
    Thansk for everybodys business last week man was it a busy one. If i didnt get back to anybody im sorry please text me back . After building 15 trannys last week i was wore out and took the weekend off for import showdown . Im refeshed now and ready to get back to work so if you need a tranny hit me up. Thanks toeverybody that bought trannys glad to help you guys out.
    Senior Member Patterson's Avatar
    Summerville
    Im still waiting for my pm back lol when you get time man im in no hurry. Maybe you traded around with those 15 and found that b16/lsd I am needing j/k
    wheel whore
    Dec 2009
    atl streets
    i have a ls tranny grinds in 3rd would like to get a b16 tranny with a ls 5th pliz pm me would like to get it soon
    SOUTHERN SPEED
    macon ga
    just text me its easier that way 478-808-9122
    gsrthriller DustinT2219's Avatar
    Tennessee
    MIA-ATL
    Hey Bud... I have a brand new LS 5th gear assembly with countershaft, seals etc for sale.
    I just texted you.
    Let me know, good luck with your builds and bump for you.
    '93 Civic CX HB
    IA Member Dr.Greenthum's Avatar
    South Side.
    Do you have any d series trans, or just b series?
    =) JF868849's Avatar
    Oct 2008
    BYRON
    Bump
    h22?
    SOUTHERN SPEED
    macon ga
    Default gsr 3 gear ls 3 gearwas goog tego muchas cosas mas hhhhhhhvhvhfvyufyfygyfygycy7giyod
    yyy
    I have been trading good b series trannys for bad b series plus cash for years on here so i figured i would make a thread on it . i have probably sold over twenty trannys on here with never a bad one or any problems plenty of people to rep me. If your tarnny is grinding dont buy another one and set it to the side trade it in on a good one save your self some money and time . Also have the confidence that your getting a good tranny buying one from a ia sponsor southern speed which is me. If youn dont like your ls tranny and wnat a b16 hit me up i can i give you a b16 for your ls plus cash . Best way to reach me is 478-808-9122 just text me.I also install lsd,final drives ,and hybrid trannys .
    Just to give you a idea on pricing this is how it goes.
    B16 grinding in one gear - yours plus 300 for a fresh b16
    gsr grinding in one gear - yours plus 200 for a fresh gsr
    SOUTHERN SPEED
    macon ga
    Quote Originally Posted by nitrosboom18 View Post
    yyy
    Im sorry man i have no idea what your talking about lol.
