Results 1 to 14 of 14
Thread: tranny prob!!!!
    F.O.C.U.S jdmshytyo87's Avatar
    Oct 2009
    cedar bluff, al
    Default tranny prob!!!!
    ok just put a z6 in with si tranny got it all in and started it up, everything was fine went in to every gear and shifted fine, well stopped to get gas and got back in and with the clutch pressed in, it would not go into gear at all, but did just fine before i stopped, its like its not pushing the fork far enough. any advice?
    Dec 2008
    Northside
    if u can go into gear with the car off but not with the car on then something broke on the clutch it self
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Oct 2009
    cedar bluff, al
    its weird because it was smooth as hell when i got to the store but after that its like it not building up enough pressure to push the fork back.
    Oct 2009
    cedar bluff, al
    your right there was something wrong with the tranny, the clutch was in pieces.... the guy i got it from didnt tell me the clutch was bad, so i found him punched him in the face and took my 150$ back assholes now days. im a good guy to lol.... but thanks bro...
    Quote Originally Posted by *EFilliated* View Post
    Thats not always true, It could be out of adjustment.
    But I suppose since I read the rest of these replies, it was the case in this insident.
    Oct 2009
    cedar bluff, al
    now its vibrating on the passenger side when i give it gas?
    check and make sure axle is all the way in, or axle is not messed up
    if you had a worn out wheel bearing it also can do that too
    Yes, it can be a number of things, but it should make a noticeable noise if it was a wheel bearing
    Dec 2008
    Northside
    Quote Originally Posted by jdmshytyo87 View Post
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    you can go to walmart parking lot and do S figure to tell if it's wheel bearing or do a 8 figure to tell if it's axle
    Oct 2009
    cedar bluff, al
    ^^ funny you are...but it bottomed out on that side yesterday part of the road gave out it slammed on the passenger side, it only dose it under acceleration and turning to the right lol, maybe a tie rod?
    could have also bent a wheel. but it would most likely vibrate at all times.
    You probably bent something suspension wise, or the axle decided it wanted to be out.
    Oct 2009
    cedar bluff, al
    the axle is in all the way, ill take it to the alignment shop see what they say. thanks bros for the input...
