Thread: CD player Keeps blowing inline fuse.
    '92 EG Hatch Sunkenkarma's Avatar
    Flowery Branch , Ga
    Default CD player Keeps blowing inline fuse.
    So, Got me a vrcd500-sdu in my 95 DX, It took me a while but I finally got it working. It works great, the only trouble I am having is, once I get over a certain volume, it blows the inline fuse for the constant power. The CD player has 2 inline fuses, the constant and the ignition. The ignition does not have any problems as I know of, its just the constant that keeps blowing, as I said, it only happens above a certain volume. I have NO amp or Subs, I got some of the same inline fuses that it came with, and it blew them aswell. Do I need to go up in volts for the fuse or what? I am by no means a electric guy, so all help would be appreciated. Thanks.
    [/URL]
    Projects
    Do you know if this model civic has a Factory Amp ? Also it could be the radio shorting out while trying to pull more amps with higher Volume.
    Flowery Branch , Ga
    I dont know if the civic has a factory Amp, seeing as its the bottom of the line civic, I doubt it. Im not sure whats going on with it, the radio is nice and in great shape, plays perfect until high volume.
    [/URL]
    Dahlonega
    cd player itself is faulty. pulling too many amps and blowing the fuse.
    if you tried a larger fuse, it will last longer, but likely fry the radio instead...
    hope you kept the reciept.
    Flowery Branch , Ga
    The Radio is fine, we stuck it into my friend hatch, turned it all the way up, never had a problem, I tried changing to a bigger fuse for the radio under the dash, same effect, I think im going to buy some bigger inline fuses, just to see how that goes.
    [/URL]
    Senior Member mikesEK's Avatar
    over yonder
    speakers are distorting at full volume, causing internal amp in head unit to run warm/draw more current/blow fuse
    (1) dont turn up so loud ((we dont wanna hear yer bullshit anyway))
    (2)replace speakers
    (3) determine if speakers are ok ((i bet not)) then buy amplifier
    PawnShopMike
    I miss-spell big words freeqwentlee thanks Dekalb Co skhool systems
