Results 1 to 40 of 68
Thread: Project bumblebee AKA Datsun 620
    Super Certified metalmatt47's Avatar
    Jun 2010
    Powder Springs, Georgia, United States
    Default Project bumblebee AKA Datsun 620
    Just brought her home
    Conformity is the jailer of freedom and the enemy of growth.
    - John F. Kennedy
    1979 Civic Cvcc Saung's Avatar
    Tucker
    That's nice.
    Right side mirror. I don't think they're too many with that are there? Later, QD.
    Jan 2011
    Any plans?? datsun ftw looks gokd
    Jun 2010
    Not sure. lol This isn't a factory mirror. I'm not sure where it came from, but I like it.
    Quote Originally Posted by Crazydelsol View Post
    Plenty, just none that I'm moving on at the moment. Swapping a different carb tomorrow, and electronic ignition soon.
    Also picking up some 15x10's tomorrow.
    - John F. Kennedy
    Which carb are you swapping in? If that's an L-18 or L-20, the SUs might work out nicely if you can find some. It looks like it's in great shape especially considering how old it is.
    Macon, GA
    id love to have a 620 ... i really like these trucks.
    Jun 2010
    Quote Originally Posted by gogriz91 View Post
    It's an L20B. I put on a 32/36 Weber on for now.
    I actually want to go the ITB route with some Keihn CVK 40's. Just haven't worked out an intake manifold just yet, but I will!
    Quote Originally Posted by CptWitwiki View Post
    get one dude. They're literally everywhere if you're looking hard enough
    - John F. Kennedy
    Jun 2010
    Shit man, my bandwidth died.
    New pics ftw!
    Wheels/tires coming up in the next few weeks.
    I pulled the transmission because of a nasty scratching sound it developed when the clutch was in.
    Any guesses what happened?
    - John F. Kennedy
    Certified Gearhead F8d2Blk's Avatar
    Pilot Bushing?
    vBulletin Message
    Dahlonega
    good looking truck...
    too bad about the crank walk...
    Jun 2010
    Quote Originally Posted by F8d2Blk View Post
    Pilot Bushing?
    Quote Originally Posted by Cynical 1 View Post
    Close. lol Actually, the real story was that since I got the truck, I was driving around on a bum u-joint with a flat spot in the bearing (replaced it when i did the clutch) and it appears that all the crazy driveline vibrations knocked out some tranny mount bolts and well... the rest is pretty obvious.
    There was no REAL damage, just some battle scars.
    - John F. Kennedy
    Jun 2010
    Yayyyyy trucks running great now.
    Next step is going to be electronic ignition. Haven't decided what IGN control to use, but an MSD 6AL is screaming my name. Crank trigger with a dizzy delete would be cool too.
    Also gonna pick up some 40MM CVK ITB's from a bike and hack up an old manifold to piece something together.
    Last but not least my current project:
    I'm stuffing this under the bed just behind the axle between the frame rails. I'm mounting it with 1'' angled steel bolted through the frame-rails at the rear, and i'm gonna weld up a cage around it for protection. Should give me some nice results.
    - John F. Kennedy
    Tucker
    Nice truck. I have a yellow 77 Toyota that I'm working on.
    Jun 2010
    Thanks man. I love old Yota's too
    I lowered mine in the front.
    Before....
    After....
    - John F. Kennedy
    locust grove
    nice truck man, i like it.
    Is this torsion bar suspension? If so, what do you do to lower it? My brother has a 720 that we want to ca18 swap eventually, but we haven't really figured how to lower it yet, lol.
    Jun 2010
    Yup! Torsion bars are awesome.
    All he needs to do to lower his 720 is:
    1: Jack the front two tires off the ground to unload the front suspension. (don't forget the stands)
    2: You'll need a 15mm crescent wrench for the nut on top of the bars, and a 17mm 1/2'' drive on the head of the bold. Loosen the bolt to lower the suspension. Hold the nut on the back side, or it'll just spin.
    3: Make sure when you adjust them, you do both sides in equal intervals. It's gonna be tough to match them both perfect, so it will take a few tries to match both sides. Make some measurements and do your best to match them.
    4: When you drop the truck, the torsion bars settle back down pretty quickly, but going over a bump (like the gutter) a few times settles it down better. Measure and adjust.
    5: Re-index the control arm bushings when you lower it. The bushings were torqued at the original height, so you'll wear them FAST if you don't re-index. It takes just a minuet to do it. All you do is break the control arm bolts loose, and re-torque them to allow the bushings to settle back in at the new height.
    6: You'll need the front end aligned after you adjust them. It changes the whole front end. Camber, toe, etc.
    7: The front suspension is going to feel much softer after it's dropped. Since he's using a CA18, his intent is pretty obvious. Make sure he's got a good set of shocks on the truck. Poly bushings and mounts on the sway bar help a lot also, but the T/R cannot use poly bushings!!! It will put an un-godly amount of stress on the T/R and it will likely break.
    It's easy! PM me if you have any more questions. Also, get him on Ratsun.net, and he'll find an unlimited amount of knowledge on these old datto's. Some serious gear heads on there.
    - John F. Kennedy
    That is great info! +Reps for you!
    Some Weber DCOE 45s would go on there nicely
    Jun 2010
    Thanks! I love reps
    Only if I can find them at a good price. I have some goodies coming soon.
    Started with suspension work again! Front shocks went on today, rear shocks tomorrow. The fronts were absolutely blown out.
    I also scrubbed the fender wells clean and sprayed them with some cheap undercoating.
    - John F. Kennedy
    Jun 2010
    ahhhhhhh mother fucker.
    Lost my rear brakes due to a trashed rear wheel cylinder. It uses a two piece that bolts a second part on the back of the wheel cyl that holds the bleed screw and brake line. WELLLLL, my fucking bleed screw was broken off on BOTH sides. I didn't know until I had pulled the thing apart. Waiting on parts to come in tomorrow to put the brakes back together. Until then, this is how she sits.
    - John F. Kennedy
    Jun 2010
    I now have a long tube header! Gonna ditch the straight pipe and go with a Summit Racing resonator. Maybe a glass pack on top depending on the volume.
    - John F. Kennedy
    Jun 2010
    Just thought I'd update this for you guys..
    And did some body work....
    - John F. Kennedy
    That stinks. The truck was looking good.
    vBulletin Message
    Senior Member C230K's Avatar
    Feb 2012
    Idk you tell me
    Quote Originally Posted by metalmatt47 View Post
    ONE CALL THATS ALL.......clean Datsun
    AFA HOLLYWOOD PREMIER LEAGUE EST. 1998
    Macon, GA
    thats sad... plans to fix it?
    Jun 2010
    plans ehh???
    HDR-1-16 by metalmonkey47, on Flickr
    - John F. Kennedy
    Macon, GA
    Looking better already glad to see it
    Jun 2010
    _DSC0011 by metalmonkey47, on Flickr
    - John F. Kennedy
    Feb 2010
    wow, that looks down right dirty there.. LOVE it.. LOOOVE it.
    I better see you in that at the next Vintage Class meet..
    Jun 2010
    Thank you sir! Means a lot coming from a man with some pretty gnarly rides.
    Not sure if you remember me, but I actually spoke to you at Import Alliance earlier this year.
    I'll be there, as long as I get my 1 piece driveline made by then. Bringing a few other Datsun's with me.
    - John F. Kennedy
    Oct 2009
    c
    Nice, love these trucks.
    I'm about 100% sure my friend picked up your old wheels, the stock ones. Lol. I saw them FS on that FB group and told him to give you a call.
    It was looking real good before the "body work", can't wait to see what's coming
    THERE HAS NEVER BEEN ANYTHING MADE THAT DID NOT HAVE A PURPOSE
    Performance: QR25DE-T
    Unknown
    <3 old cars
    Certified Gearhead shubert's Avatar
    jasper/canton
    keep going. looks like its in a good direction.
    Quote Originally Posted by BTLFED View Post
    You are a load that should have been swallowed.
    86atlanta.proboards.com <-------Atlanta based ae86 and drift community!!
    Certified Gearhead l Gizzy l's Avatar
    Jun 2010
    Dallas, GA
    Ricer.....
    Jun 2010
    STFU Gizzy :idb: haha I'm gonna sticker bomb your car with Because Race Car stickers one day
    Sorry guys, I keep forgetting all about you over here!
    Fender mirrors and a lip from an S10.
    _DSC0240 by metalmonkey47, on Flickr
    - John F. Kennedy
    somewhere, GA
    GAHD AW MIGHTY
    This is badass dude!
    '82 TE72 SR5 Sport Coupe
    3tc
    EH3 > EH2 dimer4life's Avatar
    Duluth
    Man I miss my Datsuns! Looking good! I have a bare ported Canon single sidedraft intake manifold for that L Series if interested.LMK
    Jun 2010
    Quote Originally Posted by dimer4life View Post
    Hey man, how much would you want for? I've been regretting selling my Nismo side draft manifold for a LONG time now. I need side drafts in my life!
    - John F. Kennedy
