gotta bunch of stuff piled up, im doing some moving, and cleaning up , and need some stuff gone.
small port 232 duration 7.1mm cam set -$40
largeport 240 duration 7.56mm cam set - $40
mix and match small port and largeport cam set - $50
ae101 4agze 228mm flywheel - $150 (nego)
4agze 228mm clutch, used but like new condition - $40
ae86 sr5 black rubber bumper skin - $20
ae86 rear bumper side panels - $20
ae86 tag lights with plugs - $30
ae86 rear quarter marker lights- $20
ae86 HVAC panel, small chip in center, all cables and switches functional - $40 ------>pending
ae86 black interior kick panels -$50
ae86 oem steering wheels (3)- 2 with horn pads - $15 each
ae86 coupe rear quarter window trim with all clips and hardware $100 per side
ae86 oem shifter - $10
ae86 oem oil cooler - $25
4age bigport (6 shooter) cam gears - $20 a set
ae86 power steering pump and resevoir - $25
ae86 hood hinge set - $15
4age bigport 55mm throttle body, no tps - $20
aw11 4age 4-1 distributer - $25
ae86 wiper cowl - $15
ae86 whole door weather stripping (window, door top,and door surround) $50 a side, will seperate.
ae86 dash clock and bezel- $30 ---------->pending
ae86 black dash vent set - $20
4age small port plug valley cover - $10
aw11 4age water pump housing outlets and piping,complete - $60
aw11 4age thermostat housing- $30 (perfect for your ae86 20v swap)
ae86 4-pizza cutters, no caps, one good tire - $80obo
4age oil sending unit - $10
ae86 gts rear harness - $40
ae86 gts front harness - $50
1985 bluetop afm TPS- $25
ae92/101 oem topmount intercooler- $40
4age ae86 power steering and a/c bracket- $25
smallport 4agze intake manifold- $40
4agze j pipe- $15
ae86 rear quarter light set- $20
4agze intake pipe- $10
bluetop tvis plate- $15
4age oilpan with oem oil return - $25 --------->pending
aw11 4age sandwich plate for oil cooler- $20 ----------->pending
ae86 mirror trim- $20 for both (little trim pieces in front of mirrors)
ae86 black center console (no door cover)- $15
sc12 boost oulet plenum- $40
4agze oem abv(2)- $30each
4agze top timing covers(3)- $15 each
bluetop fuel rail- $10
bluetop injector resistor pack- $15
i dont have eyelids or buckets
i dont have gts bumpers
i dont have retractor relays
i dont have a dash
i dont have seats
i dont have glass
i dont have an ecu or engine harness
i dont have exhaust or suspension parts
i dont have a subframe or crossmember
i dont have a rearend or calipers
i dont have a trans or drive shaft
so save us both time and dont ask, thanks.
anything else,feel free to ask, i might have it lying around. please call or text me at 7zero6-6six9-6five78. please, no emails, i rarely check it. feel free to send pm's....
