Results 1 to 17 of 17
Thread: Noob question!! head studs
    Slo_ej8 chris89hatch's Avatar
    Sep 2008
    Default Noob question!! head studs
    i bought a b16 head, wanna do ls/vtec but i didnt know what kind of head stud i need to get..
    b18a4 block and b16 head
    :idb:s1cksquad
    Get b16 head studs
    Certified Gearhead DA9_Vito's Avatar
    Dec 2009
    Forsyth,GA
    Get the B16 head stud's. Cause your using a B16 head !!!
    Senior Citizen Dylan's Avatar
    Milledgeville
    gsr head studs.. b16 head studs are too long and will leave space between the block.
    Certified Gearhead dannysun's Avatar
    rome ga
    B16 will not work, u have to use Gsr or arp ls/vtec headstuds.
    H22Turbo DC4 from a roll
    Dec 2009
    Forsyth,GA
    Quote Originally Posted by dannysun View Post
    Maybe i was thinking of the LS/Vtec headstuds. I thought they were B16. Guess not lol.
    Certified Gearhead dc2gs's Avatar
    Oct 2011
    cartersville
    I have the same set up and i was told to use the studs for the head im using. So idk if i should use b16 or gsr studs.
    GSR if you are building LS/V if not the you use the head stud you are using for your head
    Oct 2011
    cartersville
    Talking
    Thanks for the info
    use the bolts/studs that match the head!!!
    Milledgeville
    I speak from experience that if you do use B16 studs it will not work. At one time I didn't know either and had the same build, lasted 30 seconds...
    Maybe there where other issues with your build, I have put more ls/vtecs together than I can remember...
    http://www.modified.com/tech/0411scc...ine/index.html
    Here are the lengths of each
    OEM B16A : 6.85"
    ARP B16A : 7.125"
    OEM B18C1 : 6.75"
    ARP B18C1: 7.250"
    so either way you go you should be fine...
    revolution big mac's Avatar
    ive gone with gsr on my past ones
    Certified Gearhead Go_Fast's Avatar
    Jun 2010
    I-575
    i've had b16 studs it my last 2 ls/vtecs. b16 studs are shorter than gsr studs
    Sep 2008
    thanks for the info guys.. 0.o
    :idb:s1cksquad
    lawrenceville,ga
    what about gsr block and b16 head (poor mans type r) what head studs do i use
    Milledgeville
    ^^ GSR studs.
