Results 1 to 5 of 5
Thread: z6
    ls2
    Anniston,Al.
    Default z6
    Picked up a 94 civic ex sedan over the weekend. When it's cold idles great. Once it warms up it idles like shit and has a knocking sound. Sounded like it was coming from the top end. It only does it once the rpms drop below 1k( aleast really audible). I pull the valve cover and see nothing wrong. Check all the the tolerances and everything looks good. I put the valve cover back on. I leaned on the motor and rocked it some apparently. I heard whatever it is move. Identical noise when i shake the engine as when it's running. So i'm guessing i need to pull the pan and check it out. Going to be #4 from the sounds of it.
    What do do you guys think?
    2006 gto 6 spd intake/wr 12.8@108
    2003 Chevrolet Tahoe Lt stock dd for the wifey
    1994 Honda civic EX Sdn stock dd for me
    Pull the pan to check rods and mains... If you find something post back, you might can save it, but slim chance...
    ls2
    Anniston,Al.
    I'm thinking rod bearing.. i will post up after i pull the pan.
    Quote Originally Posted by 1EVILZ View Post
    60-80buks to turn crank, then new bearings, maybe oil pump.. Catch it before it throws rod and you can save it...
    ls2
    Anniston,Al.
    Yeah, car isn' being driven right now. We'll see how the crank looks and see if it's scared enough to turn, polish or replace. Will still be under my budget of 1500 for a reliable work car.
