Results 1 to 15 of 15
Thread: ~~ 98 spec ITR cluster and hondata ~~
    in da clouds
    Default ~~ 98 spec ITR cluster and hondata ~~
    i have a itr cluster pulled from a 98 spec type r.
    sold
    miles:158xxx
    my teg is a 94 and everything worked but the gas needle.... the gas light works... i was reading on honda tech that you had to re wire for the needle to work (correct if im wrong).. this is only for (94-97)... 98+ its plug and play
    i also have a BNIB hondata intake manifold gasket
    price40obo!!!!
    770 595 2942 text or call
    in da clouds
    ttt
    Woodstock, Ga
    You should be able to use the motherboard on the back of your oem one. You just have to swap them over.
    in da clouds
    i did in my 96 spec that i have now
    Certified Gearhead ThEGrNGoBLiN's Avatar
    damn i want that cluster! glws bro
    in da clouds
    thanks....u should buy it ^
    in da clouds
    ttt
    in da clouds
    in da clouds
    ttt
    in da clouds
    ttt
    Duluth, GA
    I have the same cluster in my 96 and it all works fine.
    in da clouds
    ^ coo ...ttt
    in da clouds
    in da clouds
    ttt
    in da clouds
    ttt
