Results 1 to 11 of 11
Thread: Del Sol Part out
    Default Del Sol Part out
    My 93 del sol was stolen, stripped, abandoned, then totaled out by my insurance. I'm selling what was left on the car.
    del sol SI rear disc brakes(includes entire rear suspension except struts, ebrake cable, master cylinder,40/40 valve) $150
    obd1 harness with 02 sensor $75
    greddy turbo timer $50
    eg solid mounts $75
    del sol oem style cf hood (needs a good sanding and clear coat) $75
    set of 13" steelies two tires with good tread, two with low tread $150
    D16 shortblock, bottom end has eagle rods and arias 9:1 forged pistons with a slight overbore. head port and polished with titanium valve springs and retainers, had to rebuild the head while low on funds so had to replace hot side valves with stock valves, cold side are skunk 2 (condition of motor unknown because of theft) $200
    D series 5 speed tranny off a y7 shifts smooth no grinds or pop outs in any gears $150
    Competition Stage 4 Sprung Clutch and pressure plate $50
    8lb flywheel (brand unknown) $25
    Tranny is currently on the motor so can't get pics of the clutch or flywheel. I will break them apart if need be or I'll sell the whole longblock with everything together for $350. I need this stuff gone ASAP and all prices are OBO. If you're interested in something please PM or text 706 346 0351
    mmmMMMmmm cheeseeeee graveltravel's Avatar
    birmingham AL
    how much for the rear disk swap with the prop valve ONLY?
    i dont need the other parts....
    and im assuming the mounts are for d-series only?
    barrow county
    where you located? i want the harness and o2
    Located in Rome, meeting in Kennesaw area is no problem for me. The mounts should work for a B series as well I think as long as it's in an eg. Not 100% sure though since I only did D series stuff.
    Bump for needing this stuff gone. Make me an offer.
    Snellville/Statesboro
    If you have fenders in good condition, pm me
    UPROOT Photography FTW
    Motor is sold. I dont have any body parts already got rid of the shell
    Bunp
    Certified Gearhead EK Hotch's Avatar
    Canton
    Swamp
    Macon, GA
    Got the stock shifter?
