- b series motor swap
- Rep Power
- 0
b series motor swap
bout a friends 96 civic coupe with a blown d16y8. wantin to go with a b18 swap but not sure what i need for it. i got the engine, tranny, wiring, n ecu. any help appreciated.
99-00 si driver side mount 99-00 si rear t bracket
Everything needs to be obd2
youll need axles, shift linkage..mounts. thats off the top of my head.
Maybe a new harness (depends on the distributor), rear mount and bracket, shift linkage, axles. That's about it really. Good luck.
- Rep Power
- 0
ok. wiring harness is coming with it along with the computer. the engine is coming out of a 91 integra. and where can i find motor mounts n shift linkages from? i have bout a $500 budget after gettin the motor.
- Rep Power
- 18
possible at junkyard if no one haven't strip them out yet lol depend if you want aftermarket mounts or oem mounts.
You will need the mounts from a 99-00 civic Si.
Tags for this Thread
- You may not post replies
- You may not edit your posts
Forum Rules
