Results 1 to 39 of 39
Thread: B SERIES PARTS
    Default B SERIES PARTS
    selling some parts that i don't need anymore.
    farthest i will meet is in the gwinnett area for larger items
    Text me, I wont pick up numbers I know 7068702879
    can buy block and crank for 70
    ls crank covered in white grease
    $50 firm
    ls b18b1 block...cylinder walls covered with white grease
    $50 firm
    ls obdII injectors with clips, seal, and new o rings
    sold
    320cc saturated injectors with clips and newo ring seal(89 Toyota supra's ) will fit hondas need need the right gasket
    $40 obo
    370cc rc injetctors with NO clips and NO orings
    $100 firm(cosmetic damages but works fine)
    sold
    ls valve cover(valve cover is cut)
    sold
    ls intake arm and box
    $40 obo
    ls axleback(scratched on bottom and NO RUBBER MOUNTS)
    sold
    vtec cam rails..needs cleaning
    $ 15 obo
    b20 3-layer head gasket and header gasket
    sold
    b18b/a head gasket set
    40FIRM
    p75 camshaft
    $20 obo
    skunk 2 cam gears fits b series
    100 FIRM
    b18b arp head studs torqued down once
    sold
    p8r head with ls SUPERTECH valve train, kms chromly retainers (has bent valves used only for 1300 miles )
    i can take the valve train of for you if you want also for same price
    sold
    obd II b18b1 distributor with ngk wires
    sold
    blox b18b/a type r manifold(SKUNK2 rep) with 64mm tb no gasket
    Sold
    Jan 2010
    Macon
    Pm sent!!!
    a/c and hid crew member #2
    Textd you
    Daily bump
    upp
    Obo folks
    Up
    up
    Out in the Boonies
    bump for looking
    thanks bump
    Jan 2011
    Douglasville, ga
    Text me at 404-606-4669. Interested in the headgasket
    Bump
    Bump
    upp
    Upp
    new items
    Upp I know someone needs these parts
    Macon, GA
    I wish that manifold was the skunk2 knock off with the acid etched logo
    Works the same!
    parts sold
    Bump
    upppppppppppppppppppppppppppppp
    No one wants?
    upp
    update
    Bump
    upp
    uppppp
    Up
    Bump
    hmg new yr bump!
    Bump
    Certified Gearhead YoItsCarlie's Avatar
    Mar 2011
    i have a b18c5 i may be interested in trading out.
    I need the cams only if you want to trade
    up
    Up
    up
    up
    abcd
    efgh
