Results 1 to 3 of 3
Thread: turbo cams questions
    Question turbo cams questions
    what is the difference between all motor cams and turbo cams? can i use stage 3 all motor cams in a turbo car?
    over lap, all motor cams will work; Example Pro1's.. But you need to match everything correctly!!
    Don't be afraid of an 11 or 12 to 1 motor and pro 1's on Boost, been done for years my friend...
    What stage 3 cams do you have, also what compression? You may have some luck adjusting the overlap with the cam gears, and seeing big gains from low boost.. Just all depends on you set-up including turbo, piping, etc!!!
    Flowery Branch, GA
    Generally less overlap tends to help drive cylinder pressures up to help spool the turbo. The cam I am looking at currently for a street friendly build is a 280/278 cam. Less duration on the exhaust.
    ---Mike
