1JZ 1993 Nissan 240sx
contact info: Call or text 678-995-5096
email: [email protected]
1JZGTE (NAD Auto)
TDF Rebuilt R154 5speed Transmission + shifter extended and shortened
ARP 1JZ Flywheel Bolts
new R154 Clutch Fork
TRD Clutch
Custom DLS Driveshaft
Converted Wire harness
Greddy Extreme Timing Belt
HKS Black Limited Edition BOV
Apexi Dual Exhaust Tip
CXRacing radiator & FMIC
Q45 LSD
JZ Pulley Kit V2.0, 6061 Aluminum drift motion
Has AC compressor but no lines, TDF will hook u up,
1 fan pushing on condenser 2 fans pulling from rad
Tuning by Turbo Dave Fabrications:
T4 AR70 .68 TURBO SET MANIFOLD (toys-auto eBay)
365hp @ 16psi Apexi Super AFC Neo
Greddy Profec-B Boost Controller
Installed Boost cut defender
440cc injectors
255lph Walbro Fuel Pump
Currently Turbo stops gaining power at 16psi and makes 365hp , but able to push up to 24psi
Suspension:
KYB struts with Tein-S Springs
Godspeed Front Lower Control Arms
ISIS Suspension Arm Packed Valued at $379.99 (http://www.enjukuracing.com/isis-sus...sx-p-8984.html)
-Front Tension Rods
-Rear Upper Control Arms
-Rear Traction Links
-Rear Toe Links
Energy Suspension Hyper-Flex Master Bushing Kit - red (Apx$13
-Front and Rear Control Arm Bushings
-Front Strut Rod Bushings
-Front and Rear Sway Bar Bushings
-Rack and Pinion Bushings
-Rear Sub-Frame Mount Inserts
Replaced
1JZ/2JZ Front Main Seal
1JZ Cam Seal
Clutch Slave Cylinder R154
Currently sitting on 4 lug- 17***8221; Staggered Xxr Sportmaxxx***8217;s
Front 225/40 Rear 245/45
3/4 Wheels have curbage.
Jensen DVD with Ipod Conection
Rockford Fosgate R500-1 500w Mono Sub Amplifier
The car is running super strong and has just been sitting the majority of the summer mainly bc its been hot as hell and it has no ac. Secondly since it turned summer, its had a overheating issue. Cant find leaks even put snapon tester on rad to check, 1 fan pushing 2 pulling, headgasket is fine, pulled the thermostat. Im thinking radiator possibly clogged or waterpump. It only overheats when driving on a hot day for about 30min or on a long trip. Other issue is the car just killed a second battery so im thinkin alternator and mayb a switch to cut off all electricity. Body and interior does need some work, passenger quarter panel got messed up when a tire de-lambed on me (will take more pics asap). I mainly only cared about power. Thats it. Give me a call, come check it out. Oh... it needed emissions 2months ago which ill have taken care of ASAP.
[/B]
