Results 1 to 3 of 3
Thread: Hehrruh Frush. Advise needed by the masters.
    User Sicko's Avatar
    Oct 2008
    Augusta/Detroit
    Default Hehrruh Frush. Advise needed by the masters.
    So...ahh. Is there a formula to work with or is it a matter of just slapping some wide a** rims on a car and then working with spacers? Thinking about going w-i-d-e with the new daily driver (2012 Fucus) and am trying to guesstimate on what size tires to use or if I should sell the rims and start over in a more conservative manor.
    stock- 17x7 50mm offset.
    28mm front and 35mm rear between outer lip to outer most fender surface.
    Purchased: 18x8.5 38mm
    By my calculations, these rims will be outboard of the fender by 3 mm in the front and inboard of the rear fender surface by 4mm with no current camber offerings for the car and not a lot of play in current suspension from what I read. (car will still have an inch wheel gap after Eibach springs are put in.
    Do I dare go with a 215 on these rims to roll the sidewalls? No, car will never be on a track.
    Thanks in advance for any insight.
    I gots stuff..probaby some of it is cooler than yours, while not as cool as theirs...But stuff comes and goes and should never be used to judge someone on their character...Stuff doesnt make the man. Men make the stuff. -Unless a woman made the stuff.
    You can do 215's all day long on the 8.5" wheel...225 if you want a mild stretch. I am doing 225 on my 9.5's. Based on your info, you wheels will still be in 11mm inside your fender. You can do a 5mm spacer to bring it out a little, but anything more than that you will want to do a bolt-on spacer to be safe. They make as small as a 15mm bolt-on spacer, but it will need to be tested on your car first since sometimes the wheels will not cover your stock studs.
    User Sicko's Avatar
    Oct 2008
    Augusta/Detroit
    Thanks for the info. I edited initial post with more accurate measurements.
