Results 1 to 14 of 14
Thread: Blown head gasket ! ?
    San antonio 210
    Exclamation Blown head gasket ! ?
    How do I know if I blew m head gasket. Some of the stuff leading up to me thinking this. My car would use all the water up from the radiator and over heat. I wasnt driving the car but my gf said that it started smoking and the car just shut off and wouldnt crank. Now when I try to crank it makes a winding like noise.
    Probably finally blew bad enough to lose compression
    San antonio 210
    would a compression test tell me for sure or is there any other way ?
    Yes, check compression, If they are all low, usually a blow headgasket is a culprit, but a leakdown and pressure test would make you definate
    San antonio 210
    also if it is the hed gasket, should there be water in the oil ?
    Rome,Ga
    Not all the times depends
    No , I have yet to see a honda to do this , unless it cracks a oil/water jacket. It could happen but very rare
    San antonio 210
    but its not a honda
    but its not a honda
    this would been great info in your OP
    San antonio 210
    Quote Originally Posted by Tech5 View Post
    this is posted in the NISSAN section.....
    bahahhaaaa I didn't know Nissan makes only 1 car 1 motor
    San antonio 210
    If you look at this section you would of known what car I was talking about, plus I was asking in general
    cool story bro
    San antonio 210
    cool story bro
    Dude either you can help/info or stop posting in here. After this im not replying ur useless post
