Thread: turbo integra major power drop when hot!
    No go del slo Jdmsol's Avatar
    Nov 2009
    Bremen
    Default turbo integra major power drop when hot!
    Sup ia I'm having a problem with my teg now when it gets hot, I've searched and can't find anything on this... here's my problem, when I first start it up and it gets to normal driving temp its a beast, but when I drive 30 mins or longer it heats up (but still norm on the gauge) and looses a lot of power over 3k rpms... like all of the torque dissapers and it stops pulling, the boost gauge still reads the same as it always does at 5lbs when I'm in boost,, What could be the problem? O and its a 96 stock ls motor.
    JDM as......
    93 accord cb7
    (traded)
    93 del sol eg1 (traded)
    94 integra dc4 (sold)
    96 db7 ls-t (daily)
    Is it tuned?
    barrow county
    flooding out, coil pack heating up or going bad. air filter needs replace.
    revolution big mac's Avatar
    dirtly ass air filter will do it sometimes drive it with no filter and see if diffrent. also is it tuned?
    Nov 2009
    Bremen
    Yes it is tuned and I haven't driven it without a filter but come to think of it my filter is dirty as hell...and sometimes after it gets real hot and I shut it off I have a hard time starting it back up, I have to press the gas while cranking to get it to start.
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    might be the filter bro
    Nov 2009
    Bremen
    Ill try it and see and lyk
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    Nov 2009
    Bremen
    Ok that didn't solve the problem. Now if it gets hot and I let it idle for a couple mins and I start to drive it blows white smoke out the exhaust under low rpms and smells like oil or gas......
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    blown head gasket?
    water in oil?
    Nov 2009
    Bremen
    Idk it goes away after I start driving and doesn't start back any...
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    Certified Gearhead Go_Fast's Avatar
    Jun 2010
    I-575
    sounds like the headgasket. id check the valve cover
    Nov 2009
    Bremen
    I got it, I changed the ignition coil runs much better. My drain line had a kink in it for some odd reason changed that out and clocked the center section to the right position and no more smoke...thanks for all the input!
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
