Results 1 to 18 of 18
Thread: obd1 b18b1 miss fire question
    barrow county
    Default obd1 b18b1 miss fire question
    everything was running fine until i took the car to drag-strip.
    before going to the strip, I used sea foam and sprayed it into the throttle body to clean the crap out but still ran fine on the way to the strip.
    on the way home, it was miss firing or bog if you want to put it that way.
    stock b18b1
    pr4 ecu
    walbro 255
    i've replace the following items:
    dizzy cap
    dizzy rotor button
    spark plug- ngk g-power, gap .044
    spark plug wire - blue ngk
    it can't be clog injectors because I'm back firing. I shot a big ass fire ball the other night.
    clutch breaking, it'll back fire a good bit.
    ---- is it possible that an injector has carbon stuck on it leaving it stick open?
    miss fire or bog only when cold starting and only when car has been running for a while, like 20miles+ and it comes and go randomly. also be doing it rapidly going 65 miles per hour+.
    when it happens, the car or engine, which ever one you prefer, does either 2 things. jerks couple times than stops until next time comes around or the engine just stop reving up. like goes quite, like as if you disengaged the clutch
    this shit has me stuck.
    either its miss fire sparking or flooding 1 or 2 cylinder out randomly <-- stuck injector(s).
    it'll fix the problem for a couple minute if I clutch and rev the motor up and down 2+ times.
    del sol? 94_teg_ls's Avatar
    sounds like a stuck injector to me crank it up and find out
    /sig
    barrow county
    crank it up and find out? its my dd, i deliver pizza in this car hahaha
    barrow county
    i've tried tons of things, can't find out whats the problem, don't know anyone around here to let me try their injectors out.
    just get a long screw driver place it on each injector put you ear on the handle end and listen for them opening and closing takes 2 mins max
    /sig
    barrow county
    i'll try that in the morning, thanks
    or unplug it.. Easiest way to find any misfire is unplugging the plug wire or injector..lol
    Quote Originally Posted by 1civic View Post
    those clips are a bitch if you dont have a pick or a small flat head
    /sig
    Quote Originally Posted by 94_teg_ls View Post
    True, guess once you've done it so long it's easier...LOL
    yeah i just use my fingers unclip one side slightly pull on the plug then push the other side of the clip and that works most of the time
    /sig
    did you do the tune up after this issue started or before ???
    barrow county
    i did the tune up after the problem.
    i check the injectors before i left for work this morning, they are all working. clicking and such.
    just got off work, im about to check fuel regulator, double check spark plugs, redo another compression test and try a different ecu.
    im leaning more at its getting too much fuel.
    You said it comes and goes, SO i would check the wiring on the injector plug.. I've seen a poorly connected injector, butt-connector, splice in harness cause this..
    Check the harness to be sure it hasn't been messed with..
    this
    sounds like it might be a bad dizzy though ? is the firing order correct?
    another thing I have ran into is POS autozone caps I have seen so many that had such a small crack you can't see either around the bolt holes or the tips and you did a full tune up but has a similar issue . Install the old cap and see how it does .
    Stang Mod slostang's Avatar
    Southside
    Could also be a coil on its way out
    revolution big mac's Avatar
    my h22 was doing that right before the coil pack went out
    coil could be it for sure , as the temp outside is so hot these things are going out left an right. I have replaced about 10 in the past month .
