Thread: FS/FT-- Used Canon XTI only 14,041 shots!
    Ballin'
    Atlanta<Georgia
    Default FS/FT-- Used Canon XTI only 14,041 shots!
    Hey all, I have a few cameras I have somehow or another collected over the years so you may see a few more ads come up if I have success with this basic one...
    I have a Canon XTI for sale, Great camera!
    Body
    Body cap
    Eye Piece
    Lexar 1 gig CF card
    Battery and wall charger, Can include a mini USB to USB cord if needed
    The camera is in good conditon back screen minimal scratches, the top cover has two surface scratches
    I just got the camera Cleaned and Checked by the local store to make sure Im not selling a broke camera... Karmas a bitch... any who, They put it on some Canon program they have and reported only 14,041 the tech told me the shutter typically last 80,000- 140,000 shots for these cameras.. And they updated firmware, and Clean the sensor...
    heres some canon info on the camera
    Type
    Type Digital AF/AE SLR with built-in flash
    Recording Media CompactFlash (CF) Card Type I & II
    Image Format 0.87 x 0.58 in./22.2 x 14.8mm (APS-C size sensor)
    Compatible Lenses Canon EF and EF-S lenses
    Lens Mount Canon EF mount
    Image Sensor
    Type High-Sensitivity, high-resolution, single-plate, CMOS sensor
    Pixels Approx. 10.10 megapixels
    Total Pixels Approx. 10.50 megapixels
    Aspect Ratio 3:2 (Horizontal : Vertical)
    Color Filter System RGB primary color filters
    Low Pass Filter Fixed position in front of the CMOS sensor
    Dust Deletion Feature (1) Automatic sensor cleaning
    (2) User-activated sensor cleaning
    (3) Dust Delete Data appended to image data
    Recording System
    Recording Format JPEG, RAW, and RAW+JPEG simultaneous recording provided. The RAW and JPEG images are saved as separate files in the CF card.
    Image Format JPEG, RAW (Canon .CR2)
    File Size (1) Large/Fine: Approx. 3.8MB (3,888 x 2,592)
    (2) Large/Normal: Approx. 2.0MB (3,888 x 2,592)
    (3) Medium/Fine: Approx. 2.3MB (2,816 x 1,880)
    (4) Medium/Normal: Approx. 1.2MB (2,816 x 1,880)
    (5) Small/Fine: Approx. 1.3MB (1,936 x 1,288)
    (6) Small/Normal: Approx. 0.7MB (1,936 x 1,288)
    (7) RAW: Approx. 9.8MB (3,888 x 2,592)
    File Numbering (1) Continuous numbering (2) Auto reset (3) Manual reset (the image numbering is reset to 0001, a new folder is created where subsequent images are saved)
    Color Space Selectable between sRGB and Adobe RGB
    Picture Style Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3
    Interface USB 2.0 Hi-Speed, mini-B port. NTSC/PAL for video output
    White Balance
    Settings Auto, Preset (Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash), Manual (Custom, or user-set Color Temperature)
    Auto White Balance Auto white balance with the image sensor
    Color Temperature Compensation White balance bracketing: +/- stops in 1-stop increments
    White balance correction: blue/amber bias +/- 9 levels, magenta/green bias +/- 9 levels
    Color Temperature Information Transmission Provided
    Viewfinder
    Type Eye-level SLR with pentamirror
    Coverage Approx. 95% horizontally and vertically
    Magnification 0.8x (-1 dpt with 50mm lens at infinity)
    Eye Point Approx. 21mm
    Dioptric Adjustment Correction -3.0 to +1.0 diopter
    Mirror Quick-return half mirror (Transmission: reflection ratio of 40:60)
    Viewfinder Information AF (AF points, focus confirmation light), Exposure (shutter speed, aperture, exposure level, AE lock, exposure compensation, AEB level, bulb), Flash (flash ready, red-eye reduction lamp on, high-speed sync, FE lock, FEB shooting, flash exposure compensation, insufficient flash warning during FE lock), White balance correction, Maximum burst, CF card full warning, CF card error warning, No CF card warning
    Depth Of Field Preview Enabled with depth-of-field preview button (with Speedlite 580EX, 430EX, MR-14EX or MT-24EX; pressing the depth-of-field preview button fires a modeling flash)
    Autofocus
    Type TTL-CT-SIR with CMOS sensor
    AF Points 9 AF points
    AF Working Range EV -0.5-18 (ISO 100 at 73°F/23°C)
    Focusing Modes Autofocus: One-Shot AF, Predictive AI Servo AF, AI Focus AF (automatic switching between One-Shot/Predictive AI Servo AF); Manual Focus (MF)
    AF Point Selection Automatic selection, Manual AF point selection
    Selected AF Point Display Superimposed on viewfinder and LCD monitor
    AF Assist Beam Intermittent firing of built-in flash (Emitted automatically when necessary under low light, and linked to all 9 AF points. Not emitted in the Landscape, Sports and Flash OFF modes)
    Exposure Control
    Metering Modes Max. aperture TTL metering with 35-zone SPC
    (1) Evaluative metering (linked to all AF points)
    (2) Partial metering (approx. 9% at center of viewfinder)
    (3) Center-weighted average metering
    Metering Range EV 1-20 (ISO 100 at 73°F/23°C with EF 50mm f/1.4 USM lens)
    ISO Speed Range Basic Zone: automatically set by the camera
    Creative Zone: equivalent to ISO 100-1,600
    Exposure Compensation (1) User-set with multi-controller (2) AEB (Auto Exposure Bracketing)
    Bracketing range: +/- 2 stops in 1/3- or 1/2-stop increments
    AE Lock Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved
    User-set: Applied with AE lock button
    Shutter Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled 1/4000 to 30 sec. (1/3- and 1/2-stop increments), X-sync at 1/200 sec. Soft-touch electomangetic release; shutter "lag time" approx. 100 msec. 10 sec. delay, 2 sec. delay with C.Fn-7-1 (mirror lockup) Remote control with Remote Switch RS-60E3 or Wireless Remote Controllers RC-1/RC-5
    Type Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled
    Shutter Speeds 1/4000 to 30 sec. (1/3- and 1/2-stop increments), X-sync at 1/200 sec.
    Shutter Release Soft-touch electomangetic release; shutter "lag time" approx. 100 msec.
    Self Timer 10 sec. delay, 2 sec. delay with C.Fn-7-1 (mirror lockup)
    Remote Control Remote control with Remote Switch RS-60E3 or Wireless Remote Controllers RC-1/RC-5
    Built in Flash
    Type Auto pop-up, retractable, built-in flash in the pentaprism
    Guide Number 43 ft./13m (ISO 100)
    Recycling Time Approx. 3 sec.
    Flash Ready Indicator Flash-ready indicator lights in viewfinder
    Flash Coverage 17mm lens focal length (equivalent to 27mm in 135 format)
    FE Lock Provided
    Flash Exposure Compensation +/-2 stops in 1/3- and 1/2-stop increments
    External Speedlite
    EOS Dedicated Speedlite E-TTL II autoflash with EX Series Speedlites
    Zooming to Match Focal Length Provided
    PC Terminal N/A
    Drive System
    Drive Modes Single, Continuous, Self-timer/Remote control
    Continuous Shooting Speed Approx. 3 fps (at shutter speed of 1/250 sec. or faster)
    Maximum Burst JPEG: approx. 27 frames (Large/Fine)
    RAW: approx. 10 frames
    RAW+JPEG: approx. 8 frames (Large/Fine)
    LCD Monitor
    Type TFT color, liquid-crystal monitor
    Monitor Size 2.5 in. diagonal with a viewing angle of approx. 160° vertically and horizontally
    Pixels Approx. 230,000 pixels
    Coverage Approx. 100%
    Brightness Control 7 levels provided
    Interface Languages 18
    Playback
    Display Format Single image, 9-image index, Magnified zoom (approx. 1.5x to 10x), Auto play, Auto review right after shooting, Histogram, Rotate, Jump
    Highlight Alert In the single image (INFO) display mode, the highlight portions containing no image information will blink
    Histogram Brightness, RGB
    Image Protection and Erase
    Protection A single image can be protected or unprotected
    Erase A single image or all images stored in a CF card can be erased if they are unprotected
    Direct Printing
    Compatible Printers PictBridge, CP Direct, and Bubble Jet Direct-compatible printers
    Printable Images JPEG images (DPOF printing possible)
    Easy Print feature Provided
    DPOF: Digital Print Order Format
    DPOF Version 1.1 compatible
    Direct Image Transfer
    Compatible Images JPEG and RAW images
    *Images to be used for wallpaper on the personal computer screen must be JPEG images
    Customization
    Custom Functions 11 Custom Functions with 29 settings
    Power Source
    Battery Battery Pack NB-2LH, quantity 1
    *AC power enabled with AC Adapter ACK-DC20
    *With Battery Grip BG-E3, size-AA batteries can be used
    Battery Life [Number of shots: Approx.]
    Temperature Shooting Conditions
    No flash 50% flash use
    At 73° F/23° C 500 360
    At 32° F/0° C 370 280
    *The above figures apply when a fully-charged Battery Pack NB-2LH is used.
    *The figures above are based on CIPA (Camera & Imaging Products Association) testing standards
    Battery Check Automatic
    Power Saving Provided; power turns off after 30 sec., 1, 2, 4, 8, or 15 min.
    Date/Time Battery One CR2016 Lithium Battery
    Start-up Time Approx. 0.2 sec.
    Dimensions and Weight
    Dimensions (W x H x D) 4.98 x 3.71 x 2.56 in./126.5 x 94.2 x 65mm
    Weight 18 oz./510g (body only)
    Operating Environment
    Working Temperature Range 32-104°F/0-40°C
    Working Humidity Range 85% or less
    Battery Pack
    Type For NB-2LH
    Rechargeable lithium-ion battery
    Rated Voltage 7.4 V DC
    Battery Capacity 720 mHh
    Dimensions (W x H x D) 33.3 x 16.2 x 45.2mm/1.3 x 0.6 x 1.8 in.
    Weight Approx. 43 g/1.5 oz.
    Battery Charger
    Type For CB-2LW
    Compatible Battery Battery Pack NB-2LH
    Recharging Time Approx. 105 min.
    Rated Input 100 - 240 V AC, 50/60 Hz
    Rated Output 8.4 V DC
    Working Temperature Range 0°C-40°C/32°F - 104°F
    Dimensions (W x H x D) 91 x 56 x 22.5mm/3.6 x 2.2 x 0.9 in.
    Weight Approx. 68 g/2.4 oz.
    Kit Lens
    Angle of View For EF-S 18-55mm f/3.5-5.6 II
    Diagonal extent: 74°20' - 27°50'
    Horizontal extent: 64°30' - 23°20'
    Vertical extent: 45°30' - 15°40'
    Lens Construction 11 elements in 9 groups
    Minimum Aperture f/22 - 36
    Closest Focusing Distance 0.28m/0.92 ft. (from image sensor plane)
    Maximum Magnification and Field of View 18mm: 0.10x (248 x 161mm/9.8 x 6.3 in.)
    55mm: 0.28x (81 x 54mm/3.2 x 2.1 in.)
    Filter Size 58mm
    Hood EW-60C
    Diameter x Length 68.5 x 66mm/2.7 x 2.6 in.
    Weight Approx. 190 g/6.7 oz.
    Case LP814
    picturesss, dont judge using a camera phone!
    PRICE ----- PRICE----- PRICE-----PRICE---- $300 OBO and will trade, for ... well lots just shoot me responsible offers
    DIGIMAN CAMERA REPAIR
    FACTORY TRAINED--- 10 YEARS EXPERIENCE--- LOW OVER HEAD, THUS LOW REPAIR COST TO YOU --- PM ME FOR EST.
    2006
    G35X
    Ballin'
    Atlanta<Georgia
    250 bump.
    2006
    G35X
    pmd
    Ballin'
    Atlanta<Georgia
    PM'd back.
    250 is rock bottom lowest no lens included, if u wanna pay more ill find you a lens///
    2006
    G35X
    Ballin'
    Atlanta<Georgia
    TTT
    2006
    G35X
    I have a brand new 18-55 ISII canon lense I'll make a killer deal to go with this camera!
    Bump for u
    Alpharetta
    check ur inbox
