Thread: 1995 integra brake booster prob ((I think))
    Senior Member mikesEK's Avatar
    over yonder
    Default 1995 integra brake booster prob ((I think))
    1995 integra LS-automatic
    The brakes don't work for sh!t , have to push hard
    To make them function , when you press the brake you can
    Hear a SHHHHHHHHHHH sound comming from firewall
    Inside the car....... I'm guess booster is bad
    Wanted to get your input before I swap it out and thats
    Not the issue
    Thanks IA
    PawnShopMike
    I miss-spell big words freeqwentlee thanks Dekalb Co skhool systems
    Pedal would be rock hard, but yes.. Check the vacuum source to the boosted to be sure it is good though..
    over yonder
    And if it IS the brake booster , is there an
    advantage to using a booster from a GSR model
    or are they all the same??
    PawnShopMike
    Quote Originally Posted by mikesEK View Post
    Same booster, no advantage..
    over yonder
    But you think that the problem? Booster?
    PawnShopMike
    Sounds like it, but to be sure find where you hear the leak, replace hose, gasket if need be.. avoid throwing parts at something to fix it..
    Try to be sure the one you have is bad, thats all..
    Remember I'm not there, and can only base my response on what you post..kk
    over yonder
    i dig ... thanks....
    PawnShopMike
