Results 1 to 10 of 10
Thread: rebuild d16 motor not starting
    Sep 2008
    oxford
    Default rebuild d16 motor not starting
    well as my title says i have a rebuild motor i just did on my eg but some how i cant get it to start or other words turn over .... itll sit there and crank but wont start... i dont know wats wrong with it ........
    i have a brand new dizzy put in it .... i got fuels coming in but yet its not working ..... so ive check it like how ever many time and well in cylinder 2 n 3 is the only two cylinder that works ... so please help me ....
    dadriver
    Privateer Racing!!
    Duluth,Ga
    Check for spark, and do you have any codes or check engine light on?
    Dahlonega
    mechanical timing set right?
    distributor 180 degrees out of time?
    spark plug wires in right order?
    everyhting plugged in?
    Macon, GA
    Valves adjusted properly? I didn't adjust my valves when I rebuilt my engine and it wouldn't start BC of that
    piston rings gapped and installed right?
    upgrade to b series
    Duluth, GA
    Check compression. My motor had spark and fuel and wouldn't start because of bad compression.
    1989 honda civic dx 4wslude's Avatar
    at a jack in a box
    is the ecu pluged in i forgot to do that one time
    Sep 2008
    oxford
    thanks to all of ya
    first it was my crank angle for my dizzy that was off and my timming was two tooth off
    so thanks alot for the help
    dadriver
    Sep 2008
    oxford
    urgh now the car starts n now a new problem
    that is first my car does this noise a grinding noise from the tranny and my clutch is cricket
    and when i step on the gas with pressure it does this high pitch noise kinda like metal hitting each other
    dadriver
