Results 1 to 11 of 11
Thread: Will integra gsr suspension fit 96-00 civic
    Rome,Ga
    Default Will integra gsr suspension fit 96-00 civic
    Please lmk if it will thanks
    Aug 2009
    Yes. It should fit.
    Rome,Ga
    Okay thanks I did not wanna sell my skunk 2 then be left with nothing
    How positive are you
    9 rpm
    Yes it will fit
    The rear Lca's are different as far as the lower strut mount but if you use your LCA's and struts you have now it will all bolt up.
    My line of work
    www.internationaljets.com
    Rome,Ga
    I have k sport lca are they the same
    rear lca's are different on 96+ civics
    (as stated above)
    But they will fit , only thing that will not work right is the front brake hose mounting . Most will just either zip tie them or leave them loose. Also the rear will work but you need to tighten them up to squeeze the lower part of the strut . Once you try , you will see what I am talking about .
    Rome,Ga
    Yeah I mean it's gonna be a temp suspension till my others come in
    temp or not it will work fine with NO ISSUES
    Yes it will fit
