Results 1 to 2 of 2
Thread: H22 turbo pistons and rods , block part out
    Statesboro / Thomaston, GA
    Default H22 turbo pistons and rods , block part out
    I have two h22 heads:
    --- one is complete with cams and cam caps (minus the vavle cover)
    --- the other one has vavles and springs installed (minus cams and cam caps and valve cover)
    asking 200 for both heads will not seperate. you buy one you get the other
    I also have a h22a1 block for sale. It is dissassembled (because i was going to build another h22 turbo motor)
    --it comes with h22 crank (took it to the machine shop and the guy said it was good to go and was up to spec)
    -- a set of mahle pistons with rings( these are the mahle golds, the ones that work with the frm liners on these blocks), new in the box still in the wraping
    --eagle h-beam rods ,new in the box still in the wrapping
    --stock fly wheel
    --harmonic balancer and bolt , balancer shaft pulley
    you also get a f22 crank and three sets of stock pistons (one set is for the f22 the other ones are for the h22, one set is out of the jdm h22)
    make offer once again i am not going to part out. and i have over $500 in the mahle pistons alone!!!if you dont believe me just google mahle gold pistons
    I also have a set of arp head studs for the h22, they were installed twice on my other motor...asking $100
    if you want all of theses parts make a offer for a package deal (will work on the price for package deal, only......i can be reached at 912-667-6897 call or text
    might consider trades for d16 or turbo d16 but it has to be of equal value
    Southside Ridin HATCH
    Location, Pictures, Prices?
