Thread: No spark????
    Jan 2003
    Conyers, Ga
    Default No spark????
    I have a 93 DA and when i bought the car it had a blown motor. I swapped the b18a1 with a b18b1 now the car wont get any spark! I put a new distributor,rotor,cap,plugs,and wires!What can be wrong with this thing?
    Duluth, G-nett
    check coil and ignitor.
    Echinsu Ocha Pher's Avatar
    Apr 2004
    Atlanta/NYC
    You are using the B1 ECU correct?
    Jan 2003
    Conyers, Ga
    No im using the A1 ecu! I thought they were the same(A1 and B1). I know the engines are the same except(A1 has egr,and B1 doesnt)So the ecu should work right? Oh yea i dont have my alternator hooked up yet,that wont affect anything right?(car should run off just the battery)
    RISKY RISKYB's Avatar
    athens
    TRY LOOKING A YOUR MAIN FUSES
    Jan 2003
    Conyers, Ga
    ok cool, i did melt the cover to my fuse box under the hood!!
    DC5-R
    Gwinett
    Quote Originally Posted by b19wheels
    lol, well that explains alot now doesnt it
    Jan 2003
    Conyers, Ga
    i checked the fuse box and it was fine! It only had burns on the cover!!
    MOSTLY LIKELY IT IS UR IGNITOR CHIP CHANGE IT
