Results 1 to 3 of 3
Thread: Need help with horn/aftermarket steering wheel
    Certified Gearhead TattooedFish's Avatar
    May 2011
    Barnesville GA
    Default Need help with horn/aftermarket steering wheel
    Ok so I got a aftermarket steering wheel I understand the concept that one wire is hot one is ground what i cant figure out is how do you hook it up to work without having a bunch of wire twisting around the steering wheel getting knotted up and shorted out behind the wheel I've looked online but still have not figured it out
    http://www.importatlanta.com/forums/...uild-with-pics <---- My H22a Swap Pm Me if you got parts
    GET It Ima HUSTLER youngmill's Avatar
    Some Where Gettin Money And My Women Be BAD. TalkIN Dollar Signs! I know You Heard About It.
    Can't you pop out the center cap of the wheel? There should be wires located inside that cap. Every one I had was like that
    Sent from my SELF MADE using Tapatalk
    May 2011
    Barnesville GA
    This one has a wire running to a metal ring of course the ring doesn't reach far enough to act as a ground as it should. The should include some kind of ribbon setup similar to te ars cable for the horn but no that would make too much sense lol
