Thread: 92 integra help wont start
    FREE BUJU StarBwoy's Avatar
    IDK
    Default 92 integra help wont start
    ok i have a 1992 integra wont start since i had it i put a axel,ecu an dizzy . the car has a wire tuck but i kno that not the prob because it ran before.ok 2 month ago i put a new fuel pump in and i started the car and it ran .the car had little gas in it so i think i ran out of gas and tried to start 2 time with no gas .had the the car sittin in my gargage because it needed a axel before i put the axel in the car i painted the motor . i clean off the grounds becasue i painted over them ..... thermostat and tran grounds put the axel in and more gas
    try to start it and nothing all i hear is a noise coming from under the dash .the noise is coming from the fuel relay when i turn the key it makes 2 click but i also hear another clicking sound every time i turn the key it from a smaller relay on the side of the radio frame . and when i push down the clutch i hear the same clickin as if i didnt push down the clutch and also i dont hear my fuel pump prime .i crack the nut on the fuel filter in the bay and no gas and the starter not making any noise
    i checked
    all the fuses
    i changed the fuel relay
    i check grounds
    and i have a new battery
    plz helppp me lol
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    Rome,Ga
    Will the car turn over? Just wont run?
    Also I have all the relay in ignition switch if u need it I will sell them cheap lmk if
    U find out what the prob is
    Also do u have a Cel light constant on while ignition switch turn on?
    IDK
    the car wont turn over at all and i got a hole bunch of relay but thanks
    and ima take the fuel pump out and test it
    and yes the cel light stays on ...wat does that mean?
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    Rome,Ga
    Ur ecu could be bad also
    May-b your ignition switch
    That will cause it not to pump fuel or turn over
    IDK
    Quote Originally Posted by terrytowe22 View Post
    i found out why the pump not working lol i need a new pump again .my bro said i keep trying to start the car with no gas .
    now on to the next prob motor not cranking
    and the ecu is good
    btw when i took the pump out it was all coroded with white stuff
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    Rome,Ga
    I got u a fuel pump also 30 bucks good
    Test the starter!! Run a 12v wire from the Big bolt on the starter, then remove the little wire and touch your 12v wire to see if it turns over, if it just clicks then starter is bad!! .. If it does then go to the safety neutral switch on the clutch pedal and unplug it, use a jumper to each side on the plug, try to start car with key..
    Now just a dummy question, but do you have a ground from the frame rail to the tranny? If not then make one and see if it starts..
    Its easy to check the ground or the starter, so start with ground.. then go to starter!!
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    is this an auto car just thought id ask cause my friend has one and it kick some kind of automatic code some times and the light next to the shifter starts blinking and it wont run till he fixes it or resets it some how if not auto then idk!
    IDK
    THIS WORK MY CAR RUNS STILL CANT USE THE KEY LOL BUT ILL FIND OUT AND IT A 5SPEED THANKS GUY GLS
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
