Thread: Swapping Motor D Y7 to Z6, have some questions?
    Apr 2011
    Lightbulb Swapping Motor D Y7 to Z6, have some questions?
    I'm not sure everything I need so I figured I would ask here.
    I'm running Boost.
    Car: 1996 civic hatch (SIG)
    This is my First motor swap..
    I have a chipped P28 Ecu that alll so far....
    (1) What do I need to hook Vtec up?
    (2) Do I need a difference wire harness?
    (3) I noticed the mount looks different do i need different mounts?
    (4) How do I relocated my battery?
    (5) How do I do a mid wire tuck just to clean the engine bay?
    ( I have my the engine bay is completely empty right now)
    Quote Originally Posted by GlennsEK View Post
    I'm running Boost.
    You will need to convert from 3 wire iacv - 2 wire iacv, add vtec solenoid, vtec pressure, (normally knock sensor as well, however p28 does not look for this) and rewire dizzy.
    You can use your y7 harness, and modify it or
    You can also use a 96-98 civic EX harness, which would have everything already done.
    You will need to use the y7 mounts, as well as the mount that bolts to the engine on the driver side behind timing cover
    Relocate battery, run power to where you want to go and ground it to chassis..
    Apr 2011
    Thank you for quick as response I'll be coming by and getting it tuned hopefully next week.
    If you need your harness modified, drop it off, same day service plug and play just did one tonight!
    Apr 2011
    What do you charge for that? I can't use a 95 civic vtec harness for the z6?
    No, the only thing you can use it for is the plugs that you need, IACV,vtec etc. Other than that its useless to you.
    Apr 2011
    Okay bro thanks
