Thread: ? about my engine temp
    05srt4
    Jun 2009
    Upatoi, Georgia, United States
    Default ? about my engine temp
    for some reason my del sol is running colder then it should be, ive already replaced the thermostat and i still reads that its running under normal temps.
    have you checked this with a thermometer ?
    I use a laser(gun type ) thermal reader and read the actual engine temp at the thermostat .
    Is your upper hose really hot when warmed up , or slightly cooler ?
    Honestly I always like mine to run cooler , I usually by a colder thermostat to do so. Colder engines perform better and last longer .HEAT kills engines
    x2
    05srt4
    Jun 2009
    this is true, but i heard lower temp engines kill gas milage?
    Quote Originally Posted by smart_ion View Post
    Yes, just like winter kills peoples gas mileage, ecu will run a little richer mixter!
    depends if you're comparing your car to a honda fit then yes, but if you compare your car to a 93 chevy dually then No lolol
    what kind of radiator do you have? some times a dual core aftermarket radiator will make it run a little cooler then normal.
