Thread: d16z6 bogs and idle
    Default d16z6 bogs and idle
    i have a 89 civic d16z6 swap. it runs perfect when engine is cold and until engine starts to warm up it'll bog? change dizzy 1 weeks ago, fuel filter was change about october last year, put in 255 warboro fuel pump last year during november. I"m using the f22 injectors.
    This only happens if i use my p28 ecu but if i use p06 chip up ecu if don't have this problem. could it be my ecu? i hate running the po6 ecu because the p28 runs better and stronger... from my theory.
    any help.
    Dec 2008
    Northside
    the problem is ur putting shit on ur motor u clearly dont need. 255 walboro really? f22 injectors? and u wanna run a stock SOHC ECU.
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    it was running like this before i up grade these parts...so what would make a difference.
    Could be ecu I would try that ecu in another persons car and see how it runs
    Quote Originally Posted by *EFilliated* View Post
    255 walboro is fine he has a stock regulator it can't push any more then allowed anyways .I like them in my cars because I am so weird and might throw a turbo one day or nitrous so leave it in for a upgrade later .Just don't be messing with a adjustable regulator and he will be fine .
    appreciate that tech5. i also try my p28 in another vehicle and it has no problem with it. i guess we didn't ride it long enough for the ecu to relearn and re program.
