Thread: compression issue
    Jan 2010
    We can do business
    Default compression issue
    okay guys.
    im building an allmotor 82mm gsr...
    I did a 1 layer (middle) HG with copper spray yesterday
    Today, I find out the head was resurfaced 7 thousandths... the block was also resurfaced IDK how much.
    I'm using pr3 pistons with flat valves...
    I wanted around 12:4 comp. Now I think I'm at 12:8.
    What do you guys think? I want it to make as much power as possible but I want it to be reliable at 93 octane since it's my DD.
    With a 3 layer HG and regular valves comp should be at 11:5.
    I'm scared is above and now I have to change the HG. I can always add the other layer but since I copper sprayed it I think I may have to buy a new one.
    youre right.
    buy a new headgasket, its $50 to know its right. Run the 3 layer and be in the mid to upper 11s and youll be much better off than mid to upper 12s on 93 octane
    Jan 2010
    We can do business
    youre right.
    when can I find an oem headgasket thats 82mm for a gsr? or what if I run the top and bottom layers making it a 2 that I did not use. I should be in the lower 12s correct?
    You can order one from golden eagle
    I wouldnt piece one together personally
    Southern Speed
    Macon
    The OEM HG is 82mm just so you know.....
    Quote Originally Posted by DarKStaR View Post
    81mm
    it might open up enough to 82mm, but i know that golden eagle has an 82mm
    Southern Speed
    Macon
    I used factory one on my 82mm and had no issues, also on my 81.5mm.
    Weird .
    Wonder why they sell a different one
    Jan 2010
    We can do business
    i just did the 2 layer top and bottom with copper spray. if it blows once the car is running then ill replace it with an oem. i don't have the funds right now. but I do have a JDM h22a complete swap for sale lol
    btw im like at 12:5 which tuner said is perfect
    You can use factory up to 82, just make sure the hg does not hang over the bore. I have used stockers on 81.5 but I think max is 82.
    SOUTHERN SPEED
    macon ga
    its not that hard to put the head gasket on and see if it will work . Good luck man.
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    Jan 2010
    We can do business
    dang guys... i just redid this lol.well i have a brand new 81mm head gasket. but I'm not about to take it apart. for the third time lol.
    according to the compression calculator I should be at 11:9 with the 2 layer (top and bottom)
    add .3 for the flat valves... and .2 - .3 for the 7 thousandths off the head resurface... should put me anywhere between 12:4 to 12:6 which Morris who will be my tuner said is perfect.
